Hier ein Script, welches durch ein virtuelles Modul gestartet wird. In dem Virtuellen Modul kann die Weckzeit, sowie die Wochentage angegeben werden und der Wecker auf aktiv und inaktiv geschalten werden. Ausserdem gibt es eine Möglichkeit, Rollos oder Jalousien via RollerShutter2 von Fibaro automatisch nach dem Weckalarm zu öffnen.
Quelle: http://jonnylarsson.se/JL/ACWUT.lua
Virtual Device:
http://siio.de/alarmclock-2-1
AlarmClockStatus
AlarmClockDays1
AlarmClockDays2
AlarmClockTime1
AlarmClockTime2
INSTRUCTIONS
* add those devices you want to use in this script to "devices"
* set dimmer device to a "_maxValue"
* set "_duration" to a value in minutes for how long the dim function should be active
* to activate debug, helper and versionCheck set the value to true or false
* helper is to show all "lights" in your system.
* debug is debug :)
* versionCheck checks if script is updated. Click on "Get it"
-- SCENE SCENARIO
-- Advanced wakeup scene to turnOn lights at specified time, time you set in
-- alarm clock virtual device
-- Set value for how much the blinds should open with the slider in VD.
-- REFERENCE
-- forum.fibaro.com, lua.org, domotique-fibaro.fr, www.gronahus.se
-- Thanks to robmac, stevenvd for good LUA functions code.
-- 2015-11-01 ver 2.0.0 new version of scene and virtual device. Supports 2 alarm.
-- 2015-11-02 ver 2.0.1 list all lights in scene. Add those you want to use in 'User Settings' section
-- 2015-11-27 ver 2.1.1 adjustment of debug lines and added variable to %% globals
version = "{2.1.1}"
-------------------- USER SETTINGS -----------------------
devices = {339,341,24,256,335,337,25} -- Lights, dimmers and blinds
_maxValue = 50 -- When dimmer reach this value it will stop there
_duration = 5 -- Time in minutes for how long wakeUp should be active
debug = true -- set debug to true or false
helper = false -- loop through all devices and search for lights/dimmers/binarySwitch etc
versionCheck = true -- check if new version of script exist on server
-- EXTRA FUNCTIONS, OPTIONS
-- Start Sonos/Internet Radio
vDeviceID = 393 -- Id of Sonos virtual device
vDeviceButton = 7 -- Play
vDeviceFunc = false -- set to true to activate Sonos/Internet Radio
-- Dimmers to set to fixed value when alarmWakeup
Dimdevices = {343} -- Dimmers to set to fixed value
fixedValue = 50 -- Dimmer value
DimdevicesFunc = false -- set to true or false
--TimeOfDay variable --
varTOD = "TimeOfDay" -- TOD translate
varTODMorning = "Morgon" -- TOD Morning translate
varState = "SleepState" -- TOD translate
varStateMorning = "Vaken" -- TOD Morning translate
variableFunc = true -- set to true or false
timeNow = os.date("%H:%M")
dayName = os.date("%A")
------------- DO NOT CHANGE LINES BELOW -------------------
startSource = fibaro:getSourceTrigger();
sortedtbl = {}
tmptbl = {}
runOnce = true
alarmTime1 = fibaro:getGlobal("AlarmClockTime1")
alarmTime2 = fibaro:getGlobal("AlarmClockTime2")
alarmDay1 = fibaro:getGlobal("AlarmClockDays1")
alarmDay2 = fibaro:getGlobal("AlarmClockDays2")
blindUpLevel = fibaro:getGlobal("openBlinds")
alarmTimes = {alarmTime1, alarmTime2}
alarmDays = {alarmDay1, alarmDay2}
-- Give debug a fancy color
Debug( "orange", "WakeUpTime scene - LUA Scripting by Jonny Larsson 2015" );
Debug( "orange", "Version: "..version);
Debug( "lightgreen", "-- Set alarmtime in virtual device --");
Debug( "lightgreen", "-- Set slider to how much blinds should open --");
if alarmDay1 ~= "Off" then
Debug( "grey", "Next alarm time is set to next "..alarmDay1..":"..alarmTime1)
if alarmDay2 ~= "Off" then
Debug( "grey", "Next alarm time is set to next "..alarmDay2..":"..alarmTime2)
function timerFunction()
-- Check if alarmDay2 is in use, else remove it from tables
if alarmDay2 == "Off" then
table.remove(alarmDays, 2)
table.remove(alarmTimes, 2)
for i = 1,#alarmDays do
--Check if day and time is same as alarmDays and alarmTimes
if timeNow == alarmDays[i] and alarmTimes[i] then
-- Sort table of devices
sortTable()
--else
--if (debug) then
--Debug( "grey", "Next alarmTime is set to next "..alarmDays[i]..":"..alarmTimes[i]);
--end
setTimeout(timerFunction, 60*1000)
sortTable = function()
for i = 1,#devices do
lightItems = devices[i];
if fibaro:getType(lightItems) == "com.fibaro.FGR221" or fibaro:getType(lightItems) == "com.fibaro.FGRM222" or fibaro:getType(lightItems) == "com.fibaro.rollerShutter" or fibaro:getType(lightItems) == "com.fibaro.FGWP101" then
table.insert(sortedtbl,lightItems)
elseif fibaro:getType(lightItems) == "com.fibaro.binarySwitch" then
elseif fibaro:getType(lightItems) == "com.fibaro.multilevelSwitch" then
turnLightOn()
-- TurnOn lights, functions
turnLightOn = function()
for i = 1,#sortedtbl do
lightItems = sortedtbl[i];
fibaro:call(lightItems, "setValue", blindUpLevel)
fibaro:call(lightItems, "turnOn")
table.insert(tmptbl,lightItems)
if (DimdevicesFunc) then
for i = 1,#Dimdevices do
DimItems = Dimdevices[i];
fibaro:call(DimItems, "setValue", fixedValue);
if (vDeviceFunc) then
fibaro:call(vDeviceID, "pressButton", vDeviceButton)
if tmptbl == nil then
if (debug) then
Debug( "red",'No dimmers in table, will not run next function')
else wakeUpFunc()end
-- Now its time to turnOn some lights
wakeUpFunc = function()
if (debug) then
Debug( "green",'Start soft wakeup light')
for i = 1,#tmptbl do
lightItems = tmptbl[i];
fibaro:call(lightItems, "setValue", "0");
fibaro:sleep(200);
addValue = _maxValue / tonumber(_duration);
local currentValueLights = tonumber(fibaro:getValue(lightItems, "value"));
local newValue = currentValueLights + addValue;
fibaro:sleep(1000);
for variable = 0, _maxValue - 1, addValue do
if (variable ~= 0 and currentValueLights == 0 ) then
if (debug) then
Debug( "blue","timer stop, lights turned off");
break;
if (debug) then
Debug( "yellow",'Increase value to ' .. newValue)
--Increases the value of the lamp
fibaro:call(lightItems, "setValue", newValue);
--Waits before the next step
fibaro:sleep(60*1000);
insert2Table = function()
if runOnce then
sortedtbl = {}
for i = 1, 500 do
if ("com.fibaro.FGR221" == fibaro:getType(i) or "com.fibaro.FGRM222" == fibaro:getType(i) or "com.fibaro.rollerShutter" == fibaro:getType(i) or "com.fibaro.multilevelSwitch" == fibaro:getType(i) or "com.fibaro.multilevelSwitch" == fibaro:getType(i) or "com.fibaro.binarySwitch" == fibaro:getType(i) or "com.fibaro.FGWP101" == fibaro:getType(i)) then
table.insert(sortedtbl,i)
Debug( "grey","All your lights will be listed in a table below, add them in devices in 'User Settings' section")
Debug( "grey",json.encode(sortedtbl))
runOnce = false
------ CHECK SCRIPT VERSION ON SERVER ------
function versionChecker()
local function getMethod(requestUrl, successCallback, errorCallback)
local http = net.HTTPClient()
http:request(requestUrl, {
options = {
method = 'GET',
headers = {
success = successCallback,
error = errorCallback
content = "ACWUT.lua"
local url = 'http://jonnylarsson.se/JL/'..content
getMethod(url, function(resp)
s = resp.data
serverVersion = string.match(s, "{(.-)}");
scriptVersion = string.match(version, "{(.-)}");
if serverVersion > scriptVersion then
Debug("grey", "Checking script version...")
Debug("yellow", "There is a new version out! "..'<a href="http://jonnylarsson.se/JL/ACWUT.lua" target="_blank" style="display:inline;color:Cyan">Get it!</a>')
end,
function(err)
print('error' .. err)
---------------- SCRIPT CHECK END ---------------------
------------------ START OF SCENE ----------------------
if ( startSource["type"] == "autostart" ) or ( startSource["type"] == "global" ) then
if helper then
insert2Table()
if versionCheck then
versionChecker()
if alarmDay1 ~= "Off" or alarmDay2 ~= "Off" then
timerFunction()
else Debug( "blue","Scene is not active until you set alarmclock time and day in virtual device")
