HC2 Update 4.091 BETA
Version 4.091 BETA
This update features migration process from version 3.600, reconfiguring every device, adjusting it for changes which took place in the system. This will assure a possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please, refer to message that appears in the interface and Notification Center after finishing upgrade for further instructions.
Important!
Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process.
Resolved issues:
  • Charts in Consumption Panel are not aligned
  • GPS scenes are not converted to Lua properly
  • Firmware Update changelog is not displayed sometimes
  • Lack of translations in Diagnostic Panel
  • Magic Scene featuring removed device is inoperable
  • Magic Scene triggered by battery level is not working
  • fibaro:calculateDistance() not working in Virtual Devices
  • floating point numbers are not displayed correctly on Virtual Devices labels
  • fibaro:countScenes() not working in Virtual Devices
  • FIBARO Smoke Sensors imported from Slave Controller, with Gateway Connection feature, displays blank configuration screen on Master
  • Slave Controller, in Gateway Connection feature, can not be deleted from Master if there is no connection
  • Some special characters in Magic Scene name may preclude them from saving
  • Occasional 503 error after activating Virtual Device buttons
  • Alarm Panel is blank if no devices are added
New devices support:
  • Enerwave ZWN SC7 version 1.5
  • Leviton VRCZ4 version 0.2
  • Aspier RF 5 Scene Controller
  • RFID Readers: BeNext, Wintop, Zipato
  • Envisalink EVL-4CG Plugin (DSC alarm integration)
  • FGKF-601
  • FGCD-001
  • FGWP-102
Other improvements:
  • Multiple RGBW devices can be grouped and controlled as one (both with interface and physical switches). Integration is possible in Advanced Configuration of one of RGBW Controllers
  • After adding Dimmer, Relay Switch, Wallplug, Roller Shutter or RGBW Controller user can choose controlled device type with pop-up
  • Removing device with cross icon from device tile triggers Z-Wave removing process, with possibility of forcing it
  • Improved scene information, number of running instances and scene triggered information are displayed on bottom of scene tile.
  • Update availability is checked on Home Center booting
  • Rooms without devices assigned are displayed in Home, Scenes and Devices tab
  • RGBW color can now be set in Magic Scenes
  • New filters for displaying hidden devices on Devices tab
  • Power management notifications are now visible in Notification Center, for devices that are capable of sending them. e.g. Fibaro Dimmer 2, Fibaro Switch 2
  • Z-Wave chip malfunction notification is displayed in Notification Center in case of such event
  • New action in Magic Scenes, controlling of lights or roller shutters in rooms, also available in Lua, more details on developer.fibaro.com
Ihr solltet vor dem Update ruhig das Feedback im Fibaro-Forum beobachten.
Sofern ihr auf das BETA wechseln wollt:
Macht das Update nicht per Remote.
Macht vorher einen Neustart, damit der Speicher aufgeräumt ist.
Nach dem Drücken des Update-Buttons solltet ihr die Kiste eine zeit lang in Ruhe lassen.
Auch wenn ihr meint sie müsste fertig sein……
Ich bin beim letzten mal erst nach 30 min wiedergekommen.
Wenn es NACHDEM Update ein Fehlermeldung wegen “Zugriff verweigert” kommt - Browser-Cache löschen.
Schauen wir mal wann sich die ersten mutigen melden :slight_smile:
Gutes Update. Nur das RFID läuft noch nicht.
Ein Deaktivieren über fibaro:call(403, "setArmed", "0") funktioniert derzeit nicht!
Hi, was genau geht da nicht? Meinst du dein Script, oder das Modul an sich?
Danke, Gruß Chris
Man kann keine Sensoren mit der obigen Codezeile mehr entschärfen :wink:
Urgs, gehts noch über die Blockszenen? Wäre ja ne Ausweichmöglichkeit
Gruß Chris
Denke ich nicht, da die Blockszene im Hintergrund ja LUA nutzt ^^
Mir fehlen zwei Themen:
  • Probleme bei Versand von Benachrichtigung
  • fehlerhafte Wetterdaten
    Schade, wird dann wohl noch Monate dauen, bis es eine finale Firmware gibt, die das behebt … :frowning:
@boomx
Das Rfid läuft echt nicht? Laut Text oben sollte doch das Zipato RfiD unterstützt werden…
  • Nach 17 Stunden funktioniert Push ohne Probleme
  • Wetterdaten nutze ich leider meine eigenen :wink: Die werden aber bei YR-Wetter bleiben
  • RFID funktioniert. Nur gab es bis gerade eben keine Doku. :wink: Muss die Szene aber umprogrammieren.
ist es bei Euch möglich nach dem Beta 4.091 Update die Konfigurationsseite der einzelnen Devices anzuschauen? Bei mir wirft das System jeweils eine 403 Access Denied Exception.
Vielen Dank für Eure Hilfe.
Grüsse
Nachtrag - Sorry nicht alles gelesen. Hat sich geklärt. Danke.
shock hatte mir gestern bereits ein RFID Zipato bestellt. Hoffe es geht jetzt auch ordentlich.
http://www.siio.de/board/thema/mini-keypad-zipato/page/2/#post-46071
Ich habe noch die 4.056 Firmware.
Ist es ratsam erst die 4.090 zu installieren oder ist das egal und ich kann direkt auf die 4.091 Beta wechseln?
Update von der Version 4.070 auf die 4.091 ist in 9 Minuten ganz sauber durchgelaufen.
Jetzt melden nur 5 Bewegungsmelder das sie ein Update machen wollen, mal schauen wie lange das dauert.
Was mir mit der 4.091 aufgefallen ist, bei mir sind alle Netatmo Module ohne Daten in den Einstellungen.
Die Werte der Module werden aber übergeben und angezeigt.
Verstehe ich das im englischen Fibaro-Forum richtig, dass Push-Benachrichtigungen unter 4.091 beta nicht funktionieren?
