Liste der Softwareänderungen 4.530:
Version 4.530
New improvements:
- Added functionality of sharing gateways to other Fibaro ID users via id.cloud.fibaro.com.
- Added manual user synchronization with the button in Access Control.
- Added support for FIBARO Roller Shutter 3.
- Added temperature displaying from the built-in sensor for FIBARO Heat Controller for version 4.5 or higher.
- Added temperature sensor status displaying in the advanced configuration of FIBARO Heat Controller.
- Added possibility of changing the name of your Home Center in the configuration settings.
- Added assigning devices to categories for easier control in the new FIBARO Home Center mobile app.
- Added assigning scenes to categories for easier control in the new FIBARO Home Center mobile app.
- Added Thermostat & Heating Zone plugin, which allows to control the heating zone temperature using a physical thermostat.
Resolved issues:
- No notifications set in the advanced configuration of devices.
- Incorrect state reporting of a blind/gate in the interface.
- Mesh network reconfiguration causes delays in system operation.
- Unable to add more than one empty button in a virtual device.
- YR Weather plugin generates too many requests.
- Empty fields in the LAN settings after switching from Static IP to DHCP.
- Changing DNS and enabling remote support results in an interface error.
- Notification about no compatible backups is displayed despite having them.
- No auto-reboot after editing the location settings.
- Incorrect redirection from the PIN code change notification.
- IP camera settings tab hangs the interface.
- Security fixes for remote access scripts.
- Other minor fixes.
