V 4.531 beta released
Version 4.531 BETA
New improvements:
Added possibility of grouping the FIBARO Roller Shutters.
Added possibility of assigning each room to one of the categories.
Added notification about existing two users with the same login.
Optimized handling of FLiRS devices (eg. FIBARO Heat Controller) to improve communication with the gateway.
Added support for Oomi by Fantem MultiSensor.
Added support for Jasco ZW6302B Portable Smart Multi Sensor.
Added support for Remotec ZXT-600AU.
Resolved issues:
Weather is not updating.
Unwanted IP address blocking by the external integrations.
Possibility to change the e-mail address owned by the admin to the one already used by a regular user.
Possibility to enter in the wizard the e-mail address containing uppercase letters.
Login to the user account if the admin and user logins are identical.
User receives notifications recommending a change of the PIN code owned by the admin.
Notification recommending to change the default PIN code does not contain the user login.
FIBARO RGBW Controller device category cannot be edited.
Possibility to set the action for holding the button when the FIBARO Roller Shutter 3 works with a bistable button.
No status after editing the location settings when restarting the gateway.
No possibility to update the FIBARO Heat Controller without the external temperature sensor.
External temperature sensor status is not displayed when the sensor is not paired.
Unwanted notifications about devices status change.
Incorrect time after performing the Recovery procedure.
Other minor fixes.
siehe Fibaro Forum:
https://forum.fibaro.com/topic/42496-fibaro-system-update-4531-beta-for-home-center-2/
Ist bei mir nicht auszuwählen.
Was soll mir das wohl sagen? Lass die Finger vom Update … scnr
Nachtrag: jetzt hat es geklappt.
Dann warten wir mal auf die Überraschungen einer Beta …
Ich wollte mich überraschen lassen und bereue es jetzt…
Ich kann mich aktuell nicht mehr Anmelden. Weder lokal noch über remote.
Über die App habe ich ebenfalls kein Zugriff.
Kann mir jemand eventuell helfen?
Die letzten 3 LED´s am HC2 leuchten durchgängig.
Das Anmeldefenster beim aufrufen der Fibaro IP kommt zwar, sieht aber Verschoben aus.
Flo
Was passiert denn beim Anmelden? Kommt eine Fehlermeldung?
Cache geleert? Anderer Browser, Inkognito Modus, etc.
es geht bei mir alles wieder.
Musste aber ins Recovery Menü und habe 2x repariert.
Bei der ersten Reparatur hat sich nichts verändert. Bei der zweiten war dann alles wieder da.
Wenn ich auf anmelden gedrückt habe ist einfach nichts passiert. Cache leeren habe ich selbstverständlich probiert, ohne Erfolg.
Ein anderen Browser habe ich nicht getestet. Auf die einfache Idee kam ich nicht. Hätte möglicherweiße aber auch nichts geholfen.
Wenn ich über home.fibaro.com darauf zugreifen wollte war die HC2 rot. (Nicht erreichbar)
Das Update hat sich denk ich verschluckt.
Bin froh das es jetzt wieder geht.
Mal paar Fragen zum Backup…
Wenn ich ein Backup lokal auf der HC2 mache und ich würde die HC2 zurück setzten, ist das Backup noch da oder nicht?
Kann ich das dann ohne weiteres wieder verwenden? Bzw. sind meine Module dann wieder alle Inkludiert? Szenen und VD´s alle da?
Flo
