Update HCL 4.110 Stable
Version 4.110
This update features migration process from version 3.600, reconfiguring every device, adjusting them for changes which took place in the system. This will assure a possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please, refer to the message that appears in the interface and Notification Center for further instructions after finishing upgrade.
Important!
Updating from version 3.600 may take up to 30 minutes. Do not restart controller during update process.
Resolved issues:
  • Problems with Logitech Harmony plugin.
  • Faulty configuration of parameters of Heatit Thermostat v1.2.
  • Disappearing backups.
  • Global Cache stops working.
  • Incorrect device counting in Dashboard bar.
  • #0002195: Low Battery Level Indication on new batteries.
  • #0002267: Upgrade message inconsistent.
  • #0002270: zwave.me products not working.
  • #0003909: xml 448 - adding Meter support on endpoints.
  • #0004075: Hidden slave devices of RGB become unhidden after rebooting.
  • #0004188: v4.104 restores English user interface at daily basis.
  • Error 503 during system startup.
  • Disabled devices included in the temperature panel.
  • Time is not updated after changing location.
  • Improved event panel filtering.
  • No chart of recovery memory.
  • Force remove of devices do not work in Czech.
  • Problem with scenes protected by PIN.
  • Minor graphic fixes.
New devices support:
  • Popp Thermostat v1.0.
  • Gerda lock v1.2.
  • Russound XSource.
  • Russound XZone4.
  • Zipato RFID in version AU, IN and RU.
  • Remotec ZXT-120 versions 1.2, 1.1, 1.0, 1.3, 1.7, 1.12, 1.20, 1.21.
Other improvements:
  • Home Center Wizard - wizard used to set basic Home Center data - user configuration, firmware upgrade, alarm configuration and localization - available only for admin user.
  • For safety reasons, the admin user format was force changed to an email address format.
  • For safety reasons, the default admin password was force changed.
  • Choice of weather information source - the possibility to set various sources of weather in Home Center system, as a part of the update two sources were added: Yr.no and Yahoo. As a source of weather information you can also use other devices, e.g. temperature sensor.
  • Interactive PUSH notifications for mobile applications - a new block in scenes capable of running a scene PUSH notifications.
  • Extended information about the power consumption - the list of devices available from the Dashboard bar
  • Many devices such as switches and dimmers can be synchronized. They will react identically to action from both a button and the interface. Synchronization is possible from the advanced settings of one of the devices.
  • Improved the display of system status.
  • Change in Logitech Harmony plugin authentication - NEED TO REINSTALL THE PLUGIN.
  • Simplified control of scenes from the web interface.
  • Change in system notifications functionality - the list of notifications available from Dashboard bar.
  • Change in information about devices with low battery - the list of devices available from the Dashboard bar.
  • Extensive scenes and devices filtering - the ability to show all, hidden or only visible devices and scenes.
  • Change in information about incorrect communication with a device.
  • Rooms synchronization as a part of Gateway Connections functionality.
  • Functionality of copying scenes.
  • Functionality of energy consumption data export (CSV file).
Additional information:
  • Due to a technical issue with NEST plugin we are forced to turn off the plugin for some time. Works on certification for NEST have already started. The plugin will be available as soon as possible.
Great ;-(
After Update the new wizard comes to tell me to fill out email & password. I do so and click „ADD“… nothing goes forward because there is an JS-Error by clicking ADD jquery-1.7.2.min.js:3 PUT http://hcl/api/users/2 500 (Internal Server Error).
Testing with MacOS with Firefox and Chrome …
I have skipped the wizard, later I was choosen the wizard manually in „Configuration->HC Wizard“ … and (-? IT WORKS THEN!
Bei mir hat er sich aufgehängt während dem Update :frowning:
Bei mir das selbe Problem wie bei Ralf! Während des Updates geht es einfach nicht weiter.
Sicher, dass es nicht weitergeht?
Lass das Ding ruhig 30 Minuten in Ruhe! Geduld.
Und nicht zufrüh durch Neustart etc eingreifen!
Hi, ja habe es auf jeden Fall länger als 30 Minuten laufen lassen!
Schon sehr ungewöhnlich, beim Update davor klappte alles innerhalb von Minuten!
Also bei dem HC2 Update wurde der Screen nach dem Install-Button weiß.
Eine Progress-Bar oä gab es nicht.
Nach 30 Min waren die drei LEDs blau, Browser-Cache gelöscht und angemeldet.
Oder hast Du mal einen anderen Browser zum anmelden versucht?
Hallo, nach den Update am HCL auf 4.110 geht die admin Anmeldung nicht mehr, (hatte ich mal geändert) in der Benutzerliste ist nur der angemeldete Benutzer sichtbar und admin PW zurücksetzen geht nicht. alle Benutzer auf den Geräten haben nun auch keinen Zugriff mehr.
Setzt sich das admin PW zurück?
Hat jemand eine Idee wie ich mich als Admin wieder anmelden kann?
Sonst läuft aber alles ohne Probleme.
Alles Gut, hatte die Passwörter falsch interpretiert.
Hallo Leute,
ich habe nach dem Update keinen Remote Zugriff mehr. Nach der Konfiguration mit dem Wizzard kann ich weder auf die Webseite noch auf die HCL zugreifen. Wenn ich mir auf der Webseite ein neues Passwort erzeugen will kenmnt er meinen Account nicht, so dass ich aktuell nicht ins System komme.
Hat von euch jemand eine Idee wie ich das beheben kann.
Vielen Dank im Voraus!
Gruß Det
Die Daten zum Fernzugriff haben sich nicht geändert.
Statt mit „Admin“ ist Dein neuer Nutzername Deine E-mail-Adresse und dass Passwort, was Du Dir über den Wizard angelegt hast.
Hallo Hoggle,
danke zunächst einmal für Deine schnelle Antwort.
Ich habe die User ID und das Passwort aus dem Wizzard verwendet. Bei der Box funktioniert der Zugriff auch tadellos. Wenn ich über den Passwort Manager das Passwort auf „id.cloud.fibaro.com“ ändere funktioniert auch das. Das neue Passwort wird in der Box selber geändert und Zugriff ist möglich.
Dennoch erhalte ich mit diesen Anmeldeinformationen keinen Remote Zugriff. Weder über die Iphone App noch auf der Website „https://home.fibaro.com/cmh/signin“
In der Iphone App müssen ja neben den Zuganbgsdaten für die HCL Box ja auch noch die Remote Daten angegeben werden. Vieleicht wird da jetzt nicht richtig synchronisiert. Ich komme jedenfalls über Remote weder in die Box noch auf die Website.
Gruß Det
Nachtrag zum Post #61770:
Ich habe jetzt Zugriff auf die Website und meinen Account, aber meine HCL ist meinem Account nicht zugeordnet. Als ich die Seriennummer und MAC Adresse eingegeben habe meldet das System „HC already added by other user. Please contact tech support“
Habe ich gemacht aber bisher keine Antwort erhalten.
Gruß Det
Hallo Det,
genau das gleiche habe ich auch eben gehabt. Du kannst dich unter home.fibaro.com noch mit deinen alten Zugansgdaten anmelden. Unter den Buttons Register und Login steht Don’t have Fibaro ID yet? Try logging in with your old USER NAME. Wenn du auf den Link klickst kannst du dich bei dem alten Remote Access anmelden. Da musst du dann dein HomeCenter herauslöschen (über das große rote X). Danach kannst du das HomeCenter mit Seriennummer und MAC Adresse unter dem Fibaro ID Konto neu hinzufügen.
Hat bei mir problemlos so geklappt.
LG
Flo
Hi Flo,
das war genau der richtige Hinweis! Vielen Dank für die Info!
Vom Support habe ich mittlerweile auch die Information, dass dieser Fehler wohl häufuger vorgekommen ist bei der Umstellung.
LG Det
also bei mir ist das ADMIN Konto komplett weg. Arrrrrg
Ich weiß nicht mehr weiter. Kann mich nur noch als normaler Benutzer anmelden.
Es können keine neuen Module etc. angelernt werden.
Ich bin kurz davor die Kiste auf Werkseinstellungen zurück zu setzen.
Vielleicht habt Ihr ja eine Lösung für mich.
Danke vorab Denzel
Wenn du den Wizard durchlaufen hast, ist der Nane des SuperUsers nicht mehr Admin, sonder Deine Email-Adresse.
Suoer, Danke.
Nachdem ich mir ein neues Passwort hab senden lassen ging es. Mit dem beim Wizard vergebenen wollte es nicht laufen. Warum auch immer.
Jetzt läuft es.
