Update HC2 4.083 Beta
Beta Software Änderungsliste 4.083:
Version 4.083 Beta
This update features migration process from version 3.600, reconfiguring every device, adjusting it for changes which took place in the system. This will assure possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please refer to message that appears in interface and Notification Center after finishing upgrade for further instructions.
Important!
Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process.
Resolved issues:
  • Philips Hue plugin does not allow new user configuration. Reinstall existing plugin to enable fix
  • Wind speed available in weather conditions computed incorrectly - value too low
  • Services Restart called from 503 error page not working
  • Multiple Virtual Devices working simultaneously may cause 503 error
  • Virtual Devices hang
  • Scenes do not trigger when RAM usage is above 75%. Threshold moved to 90%
  • Device hierarchy not displaying properly for Dimmer 2 in advanced configuration
  • FIBARO Swipe imported by Gateway Connection not working properly
  • Z-Wave Weather templates lacking for devices of other manufacturers
  • Other minor fixes
Other improvements:
  • Firmware Update - wireless update of Z-Wave devices: Motion Sensor, Dimmer and Wall Plug. Availability of update for each device is showed in Notification Center and Advanced Configuration. Run update only when devices is in close range from controller (ca. 2 m). Process can take up to 30 minutes, depending on Z-Wave traffic and devices queued for update. Details on whole procedure can be found in notification displayed before every device update.
  • New, configurable scenes triggering modes available in each scene advanced configuration:
    Automatic - scene gets triggered either by one of defined triggers (device state, global variable etc.) or manually, by ‘Run’ button
    Manual - scene executes only manually by ‘Run’ button
    Disabled - scene is inactive, does not get triggered and cannot be run manually
    Visibility - scene can be hidden in all interfaces (mobile apps, web interface)
In connection to this change there are new Lua API functions:
  • fibaro:setSceneRunConfig(sceneID, runConfig), where runConfig is string that takes one of these three values:
  • TRIGGER_AND_MANUAL
  • MANUAL_ONLY
  • DISABLED
    Which will set given scene respectively to Automatic, Manual and Disabled mode. Any other value will set scene triggering mode to Automatic.
  • fibaro:getSceneRunConfig(sceneID) returns currently set value.
Old functions:
  • fibaro:setSceneEnabled(sceneID, enabled)
  • fibaro:isSceneEnabled(sceneID)
    will keep backward compatibility and continue to work without change.
bevor ihr das Update durchführt, solltet ihr die aktuelle Diskussion verfolgen:
http://forum.fibaro.com/index.php?/topic/21700-update-4083/
Moin,
ich bin ein Freund von Betas, aber diesmal juckt es in den Fingern einfach mal eine solche zu installieren. Das Z-Wave Modul Update macht neugierig und die Meldungen im Fibaro Forum sind die üblichen nach einem Update.
Ich warte trotzdem noch…
Bin ein wenig ernüchtert, dass Fibaro wirklich am OTA Update arbeitet statt sich um bekannte Probleme zu kümmern.
Neospin
Das Problem ist doch, dass die Nutzer neue Funktionen fordern. Fibaro gibt dem leider nach anstatt wie du sagst, die Bugs zu fixen.
Mit neuen Funktionen neue Kunden zu gewinnen scheint attraktiver, als Bestandskunden zufrieden zu stellen.
Dieser Effekt kehrt sich aber schnell um, dann wird der Gebrauchtmarkt mit Home Center Angeboten überflutet und Fibaro geht den Bach runter. Okay Horrorszenario, aber ich sehe das aktuelle HC2 Stable als überhaupt nicht ausgereift. Es gibt sehr sehr viele interessante Ansätze und die UI ist einmalig gut, aber das Backend ist sehr buggy.
von einen Neuling an das Forum :slight_smile:
Habt ihr schon Erfahrung mit der Stabilität oder mit dem Zipato Keypad?
Stabilität soll ganz iO sein. Zipato Keypad funktioniert weiterhin nicht.
Seit dem Update vor knapp 2 Tagen laeuft bei mir endlich wieder alles einwandfrei. Im Gegensatz zu 4.082 noch kein einziger Systemabsturz.
Kann ich bestätigen. Seit über 2 Tagen läuft es (fast) einwandfrei.
Nur die Push-Nachrichten kommen teilweise mit einigen Stunden Verzögerung an.
Von der Stabilität hört sich das ja gut an fehlt nur noch das Zipato Keypad.
Soll aber in der nächsten Beta wieder mit einfließen, bin gespannt.
Werde solange auf der 4.070 bleiben, läuft bis jetzt perfekt ohne mucken :slight_smile:
Woher hast du die Info, dass das RFID-Pad in der nächsten Beta wieder funktionieren soll?
We are planing to restore partial support in next beta version.
Official support will take some time.
Info aus fibaro bug tracker.
Da bin ich aber gespannt :slight_smile:
Glaub ich zwar nicht wirklich dran, aber die Hoffnung stirbt zuletzt. :wink:
Das bin ich auch, lassen wir uns überraschen :slight_smile:
Was ich bei der neuen beta nicht verstehe ist das Update der Module?
Man soll das Modul ca 2m vom HC2 entfernt updates aber zwave ist doch ein mesh Netzwerk.
Wenn ich das Modul in Raum XY eingefügt habe werden doch dementsprechend die Knotenpunkte gesetzt damit das Modul die Signale erhält.
Ziehe ich jetzt den z.b. Wallplug und Dackel damit in den Raum des HC2 bleiben doch die Knotenpunkte erhalten und die Signale laufen
weiterhin über die vorherigen Knotenpunkte (auch das Update). Macht doch dann keinen Sinn und wie soll ich das mit den UP Dimmer machen?
Oder hab ich hier einen Gehirnfurz?
Gruß :wink:
Ich hab die ganze Diskussion ums RFID Pad nicht mitbekommen.
Heißt das, in der stable funktioniert es, aber in den Beta-Versionen nicht?
Oder funktioniert es auch in der stable nicht?
RFID funktioniert in der 4.080 Stable nicht (mehr).
Module sollten immer nah am HC angelernt/geupdatet werden. Da die meisten Module noch nicht auf Z-Wave Plus laufen, unterstützen diese kein NWI. Deshalb muss die Kommunikation direkt mit dem HC stattfinden. Über Repeater funktioniert der Vorgang nicht zuverlässig genug.
Nur mal so als Gedankengang. Bei mir ist die HC2 recht “fest” installiert würde es theoretisch möglich sein die Antenne zu verlängern und damit durch das Haus zu laufen? Theoretisch stell ich mir das so einfacher vor. Vielleicht für viele eine einfachere alternative, wenn das gehen würde.
Würde theoretisch gehen.
wie verlängern? Einfach einen Draht an den Stecker und gut?
