ear Users,
We just released version 4.082 Beta. Full changelog is presented below.
Version 4.082 Beta
This update features migration process from version 3.600, reconfiguring every device, adjusting it for changes which took place in the system. This will assure possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please refer to message that appears in interface and Notification Center after finishing upgrade for further instructions.
Important!
Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process.
Resolved issues:
- #0003605 #0003962 #0003962 Weather is not updating (weather information provider changed to yr.no)
- Trigger information is brought back to the way it operated in 4.080
- #0003094 Alarm panel doesn’t record change of alarm state
- #0003958 Virtual Device main loop hangs
- #0003303 Remote Gateway synchronization moves devices to Unassigned
- Protection Command Class not working on devices without template
- 503 error when deleting section in some cases
- Malfunction of RGBW when changing controlled device to RGB
- NaN displayed in device serial number
- Scene Activation not working when triggered multiple times by the same id
- Mobile applications: Change of devices order not possible for non-admin users
Other improvements:
- Added support for Fibaro Button
- #0003844 Confirmation pop-up is now displayed when restoring or deleting backup
- Favicon added
- Satus bar is scrolled with page
- Notification Center is available directly on the status bar
Version 4.081 Beta
Resolved issues:
- #0003578 Danfoss thermostat shows unreal value
- #0003883 No reports from Northq Gas Meter NQ-92021
- Update progress bar stops on 30%
- Virtual Device code works after device deletion
- Satel sensors do not report lastBreached value
New devices support:
- #0003488 Aeon Labs Multisensor GEN 5
- #0003244 Zwave.me Keyfob GEN 5
- MCO MH10 PM2.5 Monitor
- MCO MH9 CO2 Monitor
- Aspire RF9518
- Aspire RF9534
- Aspire RF9536
- Leviton VRI06-1L
- Leviton VRI10-1L
- Leviton VRE06-1L
- Leviton VRF01-1L
- Leviton VRS15-1L
- Leviton VRS05-1L
- Leviton VRCS2-MR
- Leviton VRCS4-MR
- Leviton VRCZ4-MR
- Leviton VRCZ4-MO
- Leviton VRCS1-1L
- Leviton VRCZ1-1L
- Vitrum Think Simple IV Scenari
- Secure SWM301
Other improvements:
- Battery devices now work on default wake up interval when included
- Serial number is now displayed in advanced configuration of devices that declare it
- Setpoint thermostats capabilities are flexibly adapted when device is included
- #0001660, 0003525 Shutdown and reboot actions available from Lua scene, more information can be found on developer.fibaro.com
- Minor UX inconsistency fixes
CHANGES INTRODUCED IN VERSION 4.X:
- Drag & Drop for devices and scenes - available on home, devices and rooms screens. Assigning devices to rooms and changing its order is now much easier and faster.
- Temperature Panel - allows to see history of temperature changes in rooms and on each device.
- Diagnostic Panel - general information about HC working condition like CPU & RAM usage, free space on hard drive. Will be extended in future versions.
- Soft Device Reconfiguration - option allows to save settings, parameters and device ID. Thanks to that scenes with reconfigurable device will not require editing. Full reconfiguration will remove and add the device to the Z-Wave network, resulting in the loss of its settings, parameters and change the device ID…
- Mesh Network Reconfiguration - available on Configuration -> Z-Wave Network
- New Z-Wave engine - redesigned and rewritten from the scratch. Now is faster and has better support for devices.
- Z-Wave Door Locks support - controlling and PIN settings.
- Thermostats - extended controlling for thermostats from manufacturers like: Honeywell, Trane Corporation.
- Extended tamper for sensors - exclusive information for motion detection and violation of sensors.
- Fibaro Smoke Sensor extended support - level of smoke and gap to alarm level is reported and visible on charts. Sensitivity level is now easier to set.
- Fibro Motion Sensor new device - when seismometer mode is turned on new device reporting tremors is available. Charts for temperature and illuminance. Additionally information about sensor violation.
- Device hiding - device that is not in use can be hide without removing it.
- Device deactivation - deactivated device is visible in UI but can’t be controlled.
- Multithreading added for HC (server and z-wave) - now engines work much faster.
- Event panel moved - for better usability now is available in menu on right side of screen.
- Pre-Update Confirmation - installing update will prompt user additional confirmation.
- Added support for American English (EN-US)
- User rights management - moved to Configuration.
- Recovery Memory Health - can be checked on Backup & Recovery
- Backups has information about compatibility with current HC version
- Block scenes improvements - for device only available actions are visible, scene activation block added and logical conditions grouping using brackets.
- Lua Scenes - updated tool-tips for devices.
- Rest API Active Documentation - documentation and ability to test REST API requests, access at HOME_CENTER_IP/docs
Plugins:
- Plugins are grouped in categories: Safety, Cameras, Climate, Multimedia, Others
- Plugins search
- Network devices search via ARP
Plugins category Safety:
- DSC Alarm - for DSC Alarms,
- Helios Basic - integration using Basic license,
- Helios Gold - integration using Gold license
- Mobotix - for Mobotix videophone,
- Satel Alarm - for SATEL
- Modular Alarm
Plugins category Cameras
- more than 130 devices from various manufacturers
Plugin category Climate
- Carrier Furance
- WS Davis Vantage
- Nest - plugin for well-known thermostat
- Netatmo - plugin for thermostat and weather station from netatmo
Plugins category Multimedia
- LG Bluray
- LG TV*
- NC + mediabox, compatible devices: mediaBOX+ (ITI-3740SX, ADB-3740SX) and turboBOX+ (ITI-5720SX, ADB-5720SX)
- XBMC Remote Control
- Denon Amplifier
- LG Bluray
- Onkyo Amplifier
- Philips Bluray
- Pioneer Amplifier
- Samsung TV*
- Sonos
- Sony Bluray
- Sony TV*
- Logitech Harmony
- some TV Sets firmware version may not be supported
Plugins category Other
- Philips Hue
- Wake on LAN
- Planika Fireplace
Other changes, many other improvements to the system
