Update HC2 4.081 Beta
ear Users,
Version 4.081 Beta was just released. Full list of changes is presented below.
Version 4.081 Beta
This update features migration process from version 3.600, reconfiguring every device, adjusting it for changes which took place in the system. This will assure possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please refer to message that appears in interface and Notification Center after finishing upgrade for further instructions.
Important!
Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process.
Resolved issues:
  • #0003578 Danfoss thermostat shows unreal value
  • #0003883 No reports from Northq Gas Meter NQ-92021
  • Update progress bar stops on 30%
  • Virtual Device code works after device deletion
  • Satel sensors do not report lastBreached value
New devices support:
  • #0003488 Aeon Labs Multisensor GEN 5
  • #0003244 Zwave.me Keyfob GEN 5
  • MCO MH10 PM2.5 Monitor
  • MCO MH9 CO2 Monitor
  • Aspire RF9518
  • Aspire RF9534
  • Aspire RF9536
  • Leviton VRI06-1L
  • Leviton VRI10-1L
  • Leviton VRE06-1L
  • Leviton VRF01-1L
  • Leviton VRS15-1L
  • Leviton VRS05-1L
  • Leviton VRCS2-MR
  • Leviton VRCS4-MR
  • Leviton VRCZ4-MR
  • Leviton VRCZ4-MO
  • Leviton VRCS1-1L
  • Leviton VRCZ1-1L
  • Vitrum Think Simple IV Scenari
  • Secure SWM301
Other improvements:
  • Battery devices now work on default wake up interval when included
  • Serial number is now displayed in advanced configuration of devices that declare it
  • Setpoint thermostats capabilities are flexibly adapted when device is included
  • #0001660, 0003525 Shutdown and reboot actions available from Lua scene, more information can be found on developer.fibaro.com
  • Minor UX inconsistency fixes
Quote
MultiQuote
Für alle die nach dem Update ein Problem mit der (“perfekten”) Lichtszene haben gibt es HIER eine/die Lösung.
Bevor Ihr das Update durchführt:
Führt einen Neustart des HC durch, damit der RAM aufgeräumt ist.
Update durchführen
dem HC ausreichend Zeit geben!
Die Fortschrittsanzeige funktioniert nicht richtig.
Ein zu früher Neustart zerstört das Update.
Das Update ging ja mal mehr als nach hinten los.
Bei mir läuft fast keine Scene mehr. Ich kann sie noch nicht mal Manuel starten es passiert einfach nichts.
Die Nodon FB funktioniert auch nicht mehr.
Ich hoffe das die Tage ein Fix nachkommt.
Hast Du Dir mal den Link von Zero-G angesehen?
Ja, Fibaro hat einen netten Bug eingebaut :wink:
Mit der nächsten Version sollten sie das wieder fixen. Würde empfehlen die Beta auszulassen. Dann muss man nicht wieder alle Szenen durchgehen.
@hoggle ja habe ich mir angesehen, werde aber nicht richtig schlau daraus da in meine Scenen die Sachen nicht so drinnen stehen.
Poste doch mal eine Szene von dir hier, welche nicht läuft.
http://pastebin.com/WnEg8zkr
http://pastebin.com/Q4yrPaLb
Zwei Beispiele die bis jetzt liefen .
Jetzt kann ich sie nicht einmal mit Hand starten.
