This version is hot fixing version addressing some of issues reported by users.
4.036
Added Device Support:
Zipato RGBW Bulb
QEES Dimmer UNI 400W
Resolved Issues:
#0002797: Not possible to enter „rooms“ section!
#0002830: Devices with no template cannot save parameters.
#0002335: Zipato RGBW Bulb
#0002857: TypeError: undefined is not an object (evaluating ‚r.isTypeOf‘)
#0002234: sceneActivation doesn’t trigger with Zwave.me KeyFob in 4.022
#0002980: No Template for Fibaro FGSD-002
Unjustified push alarms about fire
Improved support for Fibaro Smoke Sensor
UBS Temperature is not visivble on iPhone/iPad client (was known issues)
Known Issues:
After the update clearing browser cache could be required
Power Mettering may not work properly for some devices
RGBW Controler may not work propery when used in in/out mode
Alarm Panel doesn’t work in some specific configurations
Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn’t work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks some functions may not work properly
