Update HC2 4.035
This version is hot fixing version addressing some of issues reported by users.
4.035 (4.034 was an internal version)
Resolved Issues:
#0002335: Zipato RGBW Bulb
#0002106: fibaro:call(1, “wakeUpDeadDevice”, ID) has no effect
#0002672: Battery drain AeonLabs DSB05xxx-ZWUS Z-Wave</b> ist ein drahtloser Kommunikations-Standard, welcher von der Firma Sigma Designs und der Z-Wave Alliance für die Hausautomatisierung entwickelt wurde.<br /><br />Z-Wave kann einzelne elektrische Funktionen im haus verbinden wie zum beispiel Licht, Klimaanlage, Heizung sowie Entertainment und Sicherheitssysteme.<br /><br />Z-Wave nutzt in Europa das SRD Frequenzband im Bereich um 868 MHz, in den USA sind es 908,42 MHz." class="glossaryLink ">Z-Wave Multi Sensor
#0001864: qees dimmer does not display power use
#0002134, #0002648 NetAtmo stop to work after few hours
#0002829: Events panel - Temperature not correct (decimal sepparator)
#0002810: Fibaro Motion Sensors (FW2.6): Erratic Temperature (>100 & >2000 degree C) on HC2 4.032 & 4.033
#0002260, #0002124, #0002424, #0002499, #0002516, #0002633, #0002745 RGBW on/off
#0002800: Consumption Reading (decimal place)
#0002283: Popup description incomplete
#0001671: Nomenclature - Diagnostics
#0002209: FGS221 Switch 2x1,5kW (half) in wrong room after upgrade from 3.X
#0002233: 4.022 and all 4.X : when converting from 3.590 2nd relay of the FGS221 device will be put into the wrong Room.
Locstar Door Lock (US) - status fix
Plugin for Sony TV - works with newest firmware
Lack of decimal mark in Event Panel
New Functionalities:
Template data download for devices without template.
Known issues:
After the update clearing browser cache could be required
Power Mettering may not work properly for some devices
UBS Temperature is not visivble on iPhone/iPad client
RGBW Controler may not work propery when used in in/out mode
Alarm Panel doesn’t work in some specific configurations
Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn’t work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks some functions may not work properly
Hallo Forum!
Seit dem ich das Update eingespielt habe spinnen die Fibaro Motionsensor - Z-Wave, FIB_FGMS-001.
Die Temperatur Warnmeldungen trudeln fast stündlich ein :frowning:
12.1 (Büro): Attention! Potential fire detected!
22.1 (Frühstückzimmer): Attention! Potential fire detected!
Momentan ist alles nur ein Test Betrieb mit einer Handvoll Sensoren und Schaltern. Ich möchte aber im neuen Haus möglichst viele einsetzen.
Jetzt ist ein remove device und dann ein add device noch machbar und überschaubar. Aber mit mehreren fix verbauten Teilen wird das zum reinen Albtraum.
Stecker und Schalter ausbauen (habe extra die 6,5cm tiefen Unterputzdosen verbauen lassen) dann die HC2 in 5 m Umgebung bringen und remove device und dann ein add device durchführen. Dann kann man die ganzen Szenen neu machen!
Oder darf ich dann einfach kein Update mehr machen?
Das kann wohl nicht die Lösung sein :frowning:
MIB
Hatte vor kurzem meine D-Link DCS-5222LB1 von h.264 auf JPEG konfiguriert, um auch in den Android-Apps ein Bild zu bekommen. Seit dem Update funktioniert das nicht mehr richtig.
