Update HC2 4.033 Hotfix
This version is hot fixing version addressing some of issues reported by users.
4.033 Hotfix
Resolved Issues:
#0001820: Cannot modify (edit) device group in scene if a device has been removed from system
#0001965: Device group list selection behaves erratically
#0002234: sceneActivation doesn’t trigger with Zwave.me KeyFob in 4.022
#0002249, #0002542, #0002631: Unable to change multiple user settings (Done)
#0002281: Virtual Device Slider
#0002285: NothQ Gas Meter not configured
#0002288: HC2 Craches when deleting custom RGBW program
#0002289: Alarm Go Crazy
#0002328: Magic Scenes don’t save parameters…only default ones
#0002523: v4.031 - Fibaro FGRM-221/222 - Venetian mode - Lamellas button
#0002584: Fibaro Motion Sensor stops turning associated lights on/of
#0002741: Plugin Dimmer - BeNext [BEN_PlDi]
Occasionally Error 400 after hidding plugin
Saving Magic Scenes - spinning circle when Fibaro Alarm triggered.
Many minor fixes
Known issues:
After the update clearing browser cache could be required
Power Mettering may not work properly for some devices
UBS Temperature is not visivble on iPhone/iPad client
RGBW Controler may not work propery when used in in/out mode
Alarm Panel doesn’t work in some specific configurations
Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn’t work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks - some functions may not work properly
Lack of decimal mark in Event Panel
Seit 4.033 ist das gelbe Warndreieck des KFOBs verschwunden und das NetAtmo-Plugin funktioniert endlich.
Bis einschließlich 4.032 bekam es nur ein einziges mal Werte, danach gar nicht mehr.
Seit dem Update darf ich keine Module mehr hinzufügen oder entfernen, ich bekomme dann folgenden Hinweis:
Zugriff verweigert!
403
Acces Forbidden
obwohl ich als Admin angemeldet bin.
Hat jemand ähnliche Probleme bzw. noch besser die Lösung des Problems?
Vielen Dank schon mal im Voraus!
Hallo Dirk, sowas ähnliches hatte ich auch mal. Überprüfe mal ob du den Alarm auf allen Geräten im gleichen Status hast.
Ok, danke! Werde ich überprüfen.
