Und noch ein Batterie check scipt
ich habe mal wieder ein paar Änderungen am Script vorgenommen, aber die sind fast nur kosmetischer Natur. Dabei wurde die Ausgabe für die
E-Mail und das Debug-Fenster optimiert. Die Ausgabe der Bereiche (Sections) habe ich von 4 auf 2 Stellen gekürzt. Wer da mehr braucht kann
dies in Zeile 99 (letzte Ziffer) abändern.
Changelog für Version 1.1.5
– Ausgabe für Debug Fenster optimiert
– Kleinere Codeoptimierungen
-- file:    Batterystatus.lua
-- version: 1.1.5, released on 18.02.2018
-- purpose: This script checks the batteries and sends reports via
-- email. Since version 0.6.1 and higher: The script also performs a check on
-- non battery devices and reports all devices marked as dead by HC2.
-- The batterie status is checked daily and several reports per week can be
-- emailed.
-- Due to some limitations in the HC2 with FW less then 4.130, only 980
-- characters per per e-mail could be sent.
-- For batteries that are almost empty, or a dead device is recognized,
-- a push and/or telegram messages will be sent immediately.
-- Also the status of lastBreached can be checked, so you can easely identify
-- devices whose battery may have been empty for a longer time.
-- If you have added new devices or sections, you should restart the script.
-- A manual check is possible at any time. Simply press the Start button.
-- Copyleft Mar-2017 - 2018 {jeep}  siio-forum
local version   = "1.1.5"
local oldnodeId = nil ;
-- The variables below can be changed by user.
local subject   = "Battery and device status";
local userIDs   = {2}     -- mailuser ids
local devpEmail = 25      -- devices per email
local maildays  = {1,4,6} -- 1=Sunday, 2=Monday, 3=Tuesday ...7=Saturday
local pushactiv = false;   -- true - sendpush notification
local teleactiv = true;   -- true - send message via telegram
local phoneID   = {303}   -- phone IDs for push notification
local checktime = "19:15" -- At this time the script is triggerd
local full      = 100 --between 50 and 100 the battery status is assumed to be good
local warning   = 50  --between 30 and 50 battery is running low
local critical  = 30  --below 30 battery status is asumed as critical
local empty     = 255 --probably a completely empty battery
local nBreacheds= 24  --not Breached since nn hours
local checklBreached = true; -- should lastBreached be checked
local checkSection   = true; -- if false, the section is not output.
local Debug = function ( color, message )
local function contains(days, val)
   for i=1,#days do
      if days[i] == val then
         return true
   return false
local function sendPush(text)
 if (phoneID[1] ~= nil) then
   for i=1, #phoneID do
      if phoneID[i] ~= nil then
         fibaro:call(phoneID[i],'sendPush', text)
local function sendMail(userIDs,subject,status,m)
  local subject = subject..'-'..m
  if (userIDs[1] ~= nil) then
    for m=1, #userIDs do
      if userIDs[m] ~= nil then
        fibaro:call(userIDs[m], "sendEmail", subject, status)
   status = ' ';
   print('Mail Nr. '..m.. ' sent.')
local function checklastBreached(uxtimeStamp, lbreached)
  local xseconds = (uxtimeStamp - lbreached)
  local xtime    = (xseconds /60) / 60
  local xhours   = math.floor(xtime)
  return xhours
local function formatString(name, room)
   local slength = string.len(name) + string.len(room)
   local dlength = 35 - slength
   local dots    = string.rep ("-", dlength)
   return dots
local function getSectionNamebyID(values, sectionNr, sectiontab)
  if checkSection then
     for i=1, values do
        section = sectiontab[i].id
        if section == sectionNr then
           return string.sub(sectiontab[i].name,1,2)..','
  return ''
local sym ={warn='?', ok='✔️', empty='❓', crit='⛔️', err='❌' }
local sectiontab = api.get("/sections")
local values = #sectiontab
local devices = fibaro:getDevicesId({visible = true, enabled = true, isPlugin =false })
local function checkBatteries()
  local uxtimeStamp = os.time(dt);
  local status  = '';
  local vstatus = '';
  local bstatus = '';
  local stathtml= '';
  local n = 0; -- battery device counter
  local v = 0; -- non battery device counter
  local m = 0; -- mail counter
  local x = 0; -- other devices
  Debug('withe', os.date('%c')..', Version: '.. version );
  for id = 1, #devices do
    local batteryLevel = fibaro:get(devices[id], 'batteryLevel')
    local nodeId       = fibaro:get(devices[id], 'nodeId')
    local isdead       = fibaro:get(devices[id], 'dead')
    if batteryLevel ~= nil and nodeId ~= nil and batteryLevel ~= '' then
       local name   = fibaro:getName(devices[id])
       if oldnodeId ~= nodeId then
          local room = fibaro:getRoomNameByDeviceID(devices[id])
          local sectionID = fibaro:getSectionID(devices[id])
          local lbreached = fibaro:get(devices[id], 'lastBreached')
          local sname = getSectionNamebyID(values, sectionID, sectiontab)
          if not(room == "unassigned") then
             n = n+1
             if tonumber(batteryLevel) >= warning and tonumber(batteryLevel) <= full then
                local dots = formatString(name, room)
                local statusOK = string.format("%s) %s %s, im Raum %s hat %s %s %% %s", n, sname, name, room, dots, batteryLevel, sym.ok)
                local htmlOK = "<pre>" .. string.format("%s) %s %s, im Raum %s hat %s %s %% %s", n, sname, name, room, dots, batteryLevel, sym.ok) .."</pre>"
        	    Debug('green', statusOK)
                stathtml = stathtml .. htmlOK
                status = status .. statusOK ..'\n'
             elseif
                tonumber(batteryLevel) >= critical and tonumber(batteryLevel) <= warning then
                local statuswarn = string.format("%s) %s %s, im Raum %s hat %s %s %% %s", n, sname, name, room, dots, batteryLevel, sym.warn)
                local htmlWarn = "<pre>" .. string.format("%s) %s %s, im Raum %s hat %s %s %% %s", n, sname, name, room, dots, batteryLevel, sym.warn).."</pre>"
                Debug('yellow', statuswarn)
                stathtml = stathtml .. htmlWarn
                status = status .. statuswarn ..'\n'
             elseif
                tonumber(batteryLevel) < critical  then
                local statuscritical = string.format("%s) %s %s, im Raum %s hat %s %s %% %s", n, sname, name, room, dots, batteryLevel, sym.crit)
                local htmlCrit = "<pre>".. string.format("%s) %s %s, im Raum %s hat %s %s %% %s", n, sname, name, room, dots, batteryLevel, sym.crit).."</pre>"
                Debug('red', statuscritical)
                stathtml = stathtml .. htmlCrit
                if pushactiv then
                   sendPush(statuscritical)
                status = status .. statuscritical ..'\n'
             elseif
                tonumber(batteryLevel) > full or tonumber(batteryLevel) == empty then
                local statusempty = string.format("%s) %s %s, im Raum %s hat %s %s %% %s", n, sname, name, room, dots, batteryLevel, sym.empty)
                local htmlempty = "<pre>"..string.format("%s) %s %s, im Raum %s hat %s %s %% %s", n, sname, name, room, dots, batteryLevel, sym.empty).."</pre>"
                stathtml = stathtml .. htmlempty
                Debug('red', statusempty)
                if pushactiv then
                   sendPush(statusempty)
                status = status .. statusempty..'\n';
             if tonumber(isdead) == 1 then
                local statusdead = string.format("%s) %s %s, im Raum %s ist tot. %s %s", n, sname, name, room, dots, sym.err)
                local htmldead = "<pre>"..string.format("%s) %s %s, im Raum %s ist tot. %s %s", n, sname, name, room, dots, sym.err).."</pre>"
                Debug('red', statusdead)
                status = status .. statusdead .. '\n';
                stathtml = stathtml .. htmldead
                vstatus = vstatus .. statusdead .. '\n';
                sendPush(statusdead)
                -- if teleactiv then  --Telegram sender
                --   	fibaro:setGlobal('telegram_text', name.. ' is dead! '.. os.date('%c'))
                --    fibaro:startScene(61)
                -- end
              if lbreached ~= nil and checklBreached and tonumber(lbreached) > 0 then
                 local xhours = checklastBreached(uxtimeStamp, lbreached)
                 if xhours > nBreacheds then
                    bstatus = bstatus ..sname..' '.. name ..' ('..room..') not breached since: ' ..xhours.. ' hours.\n'
             if (n % devpEmail == 0) and oldNodeId == nodeID then
                if contains(maildays, weekday) then
                   m = m+1
                   --fibaro:debug(status)
                   status = ' '
                   fibaro:sleep(500)
       oldnodeId = nodeId
       local dtype = fibaro:getType(devices[id])
       if (dtype == 'virtual_device') or (dtype == 'HC_user') or (dtype == 'iOS_device') then
          x = x+1
          v = v+1
             local statusdead = string.format("%s %s, im Raum %s ist tot! ----%s %s", sname, name, room, dots, sym.err)
             local htmldead =  "<pre>"..string.format("%s %s, im Raum %s ist tot! ----%s %s", sname, name, room, dots, sym.err).."</pre>"
    fibaro:sleep(100)
  end  --for
  if (vstatus == '') then vstatus = "No dead device found.\n" end
  status    = status .. 'Checked at: ' .. os.date('%c') ..'\n'
  status    = status ..n.. ' battery devices were checked.\n'
  vstatus   = vstatus ..v.. ' non battery devices checked.'
  separator = '------------------------------------------------------------'
  Debug('withe', os.date('%c'));
  Debug('withe', separator)
  Debug('lightgreen', stathtml)
  Debug('cyan', '------------ Summary of dead devices. -------------')
  Debug('withe', vstatus)
  Debug('cyan', '----- Summary of devices not breached for a period of time. -----')
  Debug('withe', bstatus)
  Debug('withe', "There are " .. x .." other devices, such as plugins, virtual devices, etc.")
  status = status..separator..'\n'..vstatus..'\n'
  status = status..separator..'\n'..bstatus..'\n'..os.date('%c')
     m = m+1
     status = ' ';
end  -- function
function main()
    local currenthour = string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min)
    weekday = currentDate.wday
    if currenthour == checktime then
       checkBatteries()
	setTimeout(main, 60*1000)
    main()
    if (startSource["type"] == "other")	then
       checkBatteries()
die Kälte der letzten Tage macht den Batterien zu schaffen. Mein “Door/Window Sensor” in der Garage mit DS18B20 Temperatursensor,
hatte beim letzten Check noch 84%. Und meldet heute immer noch 84%. Aber er steht im LastBreached Abschnitt des Scripts mit:
“Garagentor (Garage) not breached since: 25 hours”. Da wir aber gestern kurz vor Mittag mit dem Auto weg waren, wusste ich sofort
dass die Batterie heute Nacht die -4° in der Garage nicht überlebt hat. Ein kurzer Test mit Garage öffnen hat dann auch keine Reaktion
mehr gebracht. Batterie war knapp 8 Monate alt.
Somit ist der lastBreached Status der einzige Hinweis um eine defekte Batterie kurzfristig zu diagnostizieren, auch wenn das HC2
noch tagelang einen hohen Prozentwert mitteilen würde.
Hi @jeep,
ich habe jetzt nicht alle 10 Seiten dieses Beitrags gelesen, deshalb kann es sein, dass meine Info überflüssig ist. Es geht auch nicht um das Batterie-Check-Script sondern um die eingesetzten Batterien.
Im folgenden Artikel wurde das Verhalten von Alkali- und Lithium-Batterien unter Kälte (0°C) im Vergleich getestet.
Fazit: Klarer Sieger in allen Bereichen --> Lithium-Batterie!
Die Kapazität (mAh) der Lithium-Batterie nahm bei 0°C im Vergleich zu 21°C nur um ca. 1-4 % ab. Bei den Alkali-Batterien lag die Abnahme bei ca. 20-40 %
Zum Test: Batterie-Test: Kälte reduziert Leistung um bis zu 40 Prozent
Dirk
@jeep, da war ich wohl auf dem falschen Dampfer!
In dem Fibaro Tür/Fenster Sensor ist natürlich keine AA oder AAA-Batterie drin, sorry!
@dirkg173
Kein Problem. Gerade die ER14250 von EVE in den Fibaro Sensoren ist für ihren plötzlichen Ausfall bekannt.
@jeep, wobei das ja sowieso Lithium-Ionen-Batterien sind. Somit sollte diese Batterie-Art also vermutlich eh die beste Wahl hinsichtlich Kapazität, Lebensdauer und Temperaturunempfindlichkeit sein.
Gibt es denn bessere Alternativen auf dem Markt als die von EVE? Bei Amazon schneiden irgendwie alle Hersteller mit 3 von 5 Sternen ab…
Kann es sein das es mit 4.162 Beta Probleme beim senden EMail, Push gibt?
zumindest steht davon nichts im Fibaro-Forum.
@BlackOSX, die Frage kann ich nicht beantworten, da ich keine 4.162 beta im Einsatz habe.
Ein globlales Problem gibt es nicht, da Mail und Push mit der 4.160 eben angekommen ist.
Im Fibaro-Forum gibt es nur Hinweise das zu große E-Mails nicht mehr abgeschnitten werden,
sondern gänzlich verworfen werden, was ja so stimmt und wir hier schon festgestellt haben.
Mal sehen ob ich es heraus bekomme. Ausser die aktuelle Beta und IOS App hat sich bei mir nix geändert.
@BlackOSX, da hätte bestimmt schon jemand im Fibaro-Forum Alarm geschlagen wenn keine Emails und Push gesendet werden.
Aber damit es nicht langweilig wird stelle ich mal ein kleines Update bereit.
Keine neuen Funktionen, aber im Debug-Fenster zusätzlich eine sortierte Ausgabe nach Bereichen. :wink: Siehe screenshot.
Changelog für 1.2.0
– Sortierte Ausgabe der Geräte nach Bereichen (sections).
-- version: 1.2.0, released on 18.03.2018
-- emailed.
local version   = "1.2.0"
local maildays  = {1,3,6} -- 1=Sunday, 2=Monday, 3=Tuesday ...7=Saturday
   for i=1,#days do
         return true
   return false
   status = ' ';
  return xhours
   return dots
     for i=1, values do
  return ''
local tdev = {}
  local status  = '';
  local vstatus = '';
  local bstatus = '';
  local stathtml= '';
             n = n+1
                local tableOK  = string.format("%s %s, im Raum %s hat %s %s %% %s", sname, name, room, dots, batteryLevel, sym.ok)
                local statusOK = n..') ' ..tableOK
                local htmlOK   = "<pre>" .. statusOK .. "</pre>"
                table.insert(tdev, tableOK )
             elseif
                local tablewarn  = string.format("%s %s, im Raum %s hat %s %s %% %s", sname, name, room, dots, batteryLevel, sym.warn)
                local statuswarn = n..') '..tablewarn
                local htmlWarn   = "<pre>" .. statuswarn .. "</pre>"
                table.insert(tdev, tablewarn )
             elseif
                local tablecrit = string.format("%s %s, im Raum %s hat %s %s %% %s", sname, name, room, dots, batteryLevel, sym.crit)
                local statuscrit= n..') '.. tablecrit
                local htmlcrit  = "<pre>".. statuscrit .. "</pre>"
                Debug('red', statuscrit)
                stathtml = stathtml .. htmlcrit
                if pushactiv then
                   sendPush(statuscrit)
                status = status .. statuscrit ..'\n'
                table.insert(tdev, tablecrit )
             elseif
                local tableempty  = string.format("%s %s, im Raum %s hat %s %s %% %s", sname, name, room, dots, batteryLevel, sym.empty)
                local statusempty = n..') ' .. tableempty
                local htmlempty = "<pre>"..statusempty .. "</pre>"
                if pushactiv then
                table.insert(tdev, tableempty )
                local tabledead  = string.format("%s %s, im Raum %s ist tot. %s %s", sname, name, room, dots, sym.err)
                local statusdead = n..') '.. tabledead
                local htmldead = "<pre>"..statusdead .. "</pre>"
                table.insert(tdev, tabledead )
                   m = m+1
                   status = ' '
                   fibaro:sleep(500)
       oldnodeId = nodeId
          x = x+1
          v = v+1
    fibaro:sleep(100)
  end  --for
  print('')
  table.sort(tdev)
  Debug('skyblue', '--- Sortierte Ausgabe nach Bereichen ---')
  for i,j in ipairs(tdev) do
      Debug('skyblue',j)
  if ( not checklBreached) then bstatus = "The 'last breached status' was not checked. \n" end
     m = m+1
     status = ' ';
end  -- function
function main()
       checkBatteries()
    main()
       checkBatteries()
Mit 4.170 geht alles wieder.
@BlackOSX
Prima, eventuell war der Neustart nach dem Update der Heiler. :wink:
Passt dass so mit der sortierten Ausgabe nach Bereichen?
Alles Chic :slight_smile:
Das Script ist wirklich klasse, ich habe mein “altes” Script dadurch erneuert.
Die Ausgabe gefällt mir besonders. Mit den kleinen Symbolen das ist klasse.
Schönen Sonntag noch.
Carsten
Moin, kann mir nochmal jemand sagen, wo ich die User-ID und die Phone-ID finde??
Besten Dank von der Nordsee
Dazu gibts diesen API Call:
http://<IP-deines HC2>/api/devices?type=iOS_device
eine andere Möglichkeit über die API, z.B.:
http://HC2-IP/docs/#!/users
und
http://HC2-IP/docs/#!/iosDevices/getIosDevices
Dann auf den Button “TRY IT!” klicken.
Aber am bestens geht es so: :wink:
usr = api.get('/users')
for i,v in pairs(usr) do
    print(v.id..' - '..v.name)
print('----------------------')
ios= api.get('/iosDevices')
for i,v in pairs(ios) do
Vielen, vielen Dank @jeep!!!
Warum hat bisher noch keiner ein Lua-Script geschrieben/veröffentlicht? Ich hatte schon sämtliche hier und im fibaro.com Forum genannten Varianten ausprobiert und jedesmal erhielt ich eine Fehlermeldung. Selbst mit dem HC2-Toolkit in Verbindung mit “VirtualBox” (bin Mac User) hab ichs probiert, ohne Erfolg…
Vermutlich habe ich selber irgendwelche Fehler gemacht, letztendlich war ich der Verzweiflung nahe… :wink:
Vielen Dank noch mal!!!
Gruß,
Dirk
@jeep
Ich kann nur sagen: klasse!
Danke für das starke Skript.
Mr.Coffee
