Hey ,
ich nochmal. Hatte das Script jetz folgendermaßen zum Laufen gebracht.
local version = '2.0';
fibaro:debug('Rollershutter-Controller started for the first time (Ver.' .. version .. ')');
function rollershutter()
local sunriseHour = '7:00'; --fibaro:getValue(1,'sunriseHour');
local sunsetHour = '21:00'; --fibaro:getValue(1,'sunsetHour');
local temp = tonumber(fibaro:getValue(3, 'Temperature'));
local random = math.random(35);
local min = math.floor((random*100)/60);
if ((((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format('%02d', currentDate.hour) .. ':' .. string.format('%02d', currentDate.min) == sunriseHour)) and rollershutter_runs == 0 and tonumber(temp)>=0)
fibaro:debug('Rollershutter-Controller started (Ver.' .. version .. ')');
fibaro:debug('Sunrise... Opening rollershutters');
fibaro:debug('Waiting ' .. min .. ' min');
-- fibaro:sleep(random*100000);
fibaro:call(64, 'open');
fibaro:call(102, 'open');
fibaro:call(66, 'open');
fibaro:call(68, 'open');
fibaro:call(188, 'open');
fibaro:call(23, 'open');
fibaro:call(27, 'open');
fibaro:call(25, 'open');
fibaro:debug('Rollershutters opened');
elseif ((((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format('%02d', currentDate.hour) .. ':' .. string.format('%02d', currentDate.min) == sunsetHour)) and rollershutter_runs == 0 and tonumber(temp)>=0)
fibaro:debug('Sunset... Closing rollershutters');
fibaro:call(102, 'close');
fibaro:call(66, 'close');
fibaro:call(188, 'close');
fibaro:call(23, 'close');
fibaro:call(27, 'close');
fibaro:call(25, 'close');
while (tonumber(fibaro:getValue(176, 'value')) > 0) do
fibaro:sleep(10*1000)
fibaro:call(64, 'close');
while
(tonumber(fibaro:getValue(18, 'value')) > 0) do
fibaro:call(68, 'close');
fibaro:debug('Rollershutters closed');
elseif ((((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format('%02d', currentDate.hour) .. ':' .. string.format('%02d', currentDate.min) == sunriseHour)) and rollershutter_runs == 0 and tonumber(temp)<=0)
fibaro:debug('Sunrise... Temperatur < 0... Rollershutters stay closed.');
elseif ((((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format('%02d', currentDate.hour) .. ':' .. string.format('%02d', currentDate.min) == sunsetHour)) and rollershutter_runs == 0 and tonumber(temp)<=0)
fibaro:debug('Sunset... Temperatur < 0... Rollershutters stay opened.');
rollershutter();
Jedoch ergibt sich ein Problem bei geöffneter Tür. Ich habe 2 Kontakte jeweils vorne und hinten am haus.
Ist eine tür auf bleibt das Rollo oben allerdings auch das an der Haushinterseite welche mit dem 2.Kontakt belegt ist.
Es soll ja nur das oben bleiben bei dem auch die Tür auf ist.
Gibt es nen Tipp
Danke schonmal.
