Ich bin völlig überrascht. Es gibt also doch noch Updates für das HC2 und event. dann auch für das HCL
Ich dachte mit Erscheinen des HC3 wäre Ende damit.
Wirklich mal ein positives Ostergeschenk von Fibaro.
Liste der Softwareänderungen 4.610:
Version 4.610
Important notice:
All Z-Wave thermostats require performing soft reconfiguration to operate properly (not applicable to updates from version 4.601 beta).
New improvements:
- Important security fixes.
- Modified Z-Wave thermostat support - each setpoint type has its own device tile (requires device reconfiguration).
- Support for FIBARO Walli Controller (FGWCEU-201).
- Support for FIBARO Smart Implant (FGBS-222) version 5.2.
- Support for Era Inn Edge Tubular Motor version 1.1 or higher.
- Support for Heatit Z-Temp2 version 1.1/1.2.
- Support for Heatit Z-TRM3 version 4.0.
- Tedee lock plugin.
Resolved issues:
- HomeCenter.SystemService.reboot() function does not work.
- Some Sonos devices are not discovered by the plugin.
- Blocked UDP ports prevent the detection of some devices on the network.
- Unable to add FIBARO RGBW 2 (FGRGBW-442) in Security Mode.
- No scrollbar on device group selection window in block scenes.
- Z-Wave device firmware update attempt results in system hang-up and 503 error (requires device reconfiguration).
- Some actions that should be available for Roller Shutters in Magic scenes are missing.
- No data from YR Weather plugin.
- Other minor fixes.
Beta Software Änderungsliste 4.601:
Version 4.601 Beta
Important notice:
All Z-Wave thermostats require performing device reconfiguration to operate properly.
New improvements:
- Support for Steinel IS 140-2 version 1.0.
- Support for Steinel L810 LED iHF version 1.1.
Resolved issues:
