HC2 Update FW 4.140 Stable
Wichtig:
Macht zuerst ein Backup und auch einen Neustart.
Sofern das System wieder gut läuft, führt das Update aus und habt dabei Geduld.
Nach dem Update Browser-Cache löschen.
Version 4.140
New improvements:
  • Heating panel improvements - possibility of editing zone name, possibility of turning on manual mode in heating schedule.
  • New section dedicated to adding door locks.
  • Modification of door lock’s slots list in Scenes.
  • Support for automatic remote support deactivation
  • Ability to set RGBW Controller program in Block Scenes.
  • System stability improvement
Resolved issues:
  • Disappearing virtual devices icons after updating.
  • Error during saving scenes for devices: Swipe, KeyFob, The Button.
  • Error during setting location in Home Center configuration.
  • Error during setting manual or holiday mode for more then two zones in heating panel.
  • Force Remove does not work correctly when a language other than Polish or English is set.
  • Error during sending string from virtual device
  • Error with remembering last colour for RGBW controller.
  • Error with dedicated action for RFID readers.
  • Error with scenes for Arctic Circle.
  • Problem with snapshots from cameras.
  • Problem with UTF characters for notifications.
  • Error when loading tabs.
  • Problem with creating programs for RGBW Controller.
  • Problem with switching Block Scenes to Lua.
  • Problem with displaying icons for some devices.
  • Problem with displaying notifications.
  • Problem with displaying special signs in notifications.
  • Problem with displaying RFID reader log.
  • Minor graphic fixes.
Eben von 4.130 nach 4.140 upgedated, keine Probleme. Läuft seit 30m min.
aber Zipato RFID einlesen scheint immer noch nicht zu gehen :frowning:
Gestern Nacht über iPhone App geupdatet.
Läuft ohne Zwischenfälle.
MIB
Läuft auch ohne Zwischenfälle, Videogate bekam Push Benachrichtigung die voher nicht aktif war und auch nicht abschaltbar ist. (in meinem Fall Nachteilig weil ich die Videogates Über Bewegungsmelder FGM als Doorbell benutze). iPad schaltet auf Videgate um und Handy bimmel quitschfiedel vor sich hin bei Bewegung)
muss mich revidieren, auch die RFID´s können wieder eingelesen werden
Mit dem Update auf Version 4.140 habe ich die Verbindung zur Philips Hue Bridge verloren. Weder Szenen noch die Plugin-Oberflächen haben reagiert. Nach diversen Versuchen (Bridge Restart, HC2 Restart) habe ich das automatische Backup “4.136->4.140” zurückgespielt, danach funktionierte wieder alles.
Jedoch steht nun im Konfigurations-Tab zwar “Softwareversion: 4.140”, im Web UI prangt aber ein roter Schriftzug “4.140 Beta”.
Nach dem Update von 4.130 auf 4.140 haben die Hue-Szenen bei noch alle funktioniert.
„4.136->4.140“ zurückgespielt, danach funktionierte wieder alles.
Jedoch steht nun im Konfigurations-Tab zwar „Softwareversion: 4.140“, im Web UI prangt aber ein roter Schriftzug „4.140 Beta“.
Ist immer so, da ein Beta-Backup genutzt wurde. Für den Betrieb egal.
Gibt es eine bestimmte Empfehlung wann man das Update auf keinem Fall machen sollte (z.B. wenn man das und das hat?) oder
soll ich es mal auf gut Glück versuchen? Wahrscheinlich bleibe ich aber erstmal noch auf der 4.130, bin unsicher :frowning:
/André
Als Indikator kannst du die Beiträge hier oder im Fibaro-Forum verfolgen.
ich kann es nur empfehlen (4.140)…nach 4.120 war jede Version unvollständig und verbugt, und auch 4.130 war schlechter als Version 4.120, aber jetzt scheint bei mir bis jetzt alles super zu laufen
So ich war so mutig und habe mich an das Update der 4.140 gewackt. Bisher sehr positiv alles, sind auch neue Templates (Greenwave, Aeon) dazugekommen was ich sehr begrüße. Bisher läuft es, ich schaue es mir die tage mal genauer an
/André
ich habe die neue version installiert.
wenn ich den alarm mit dem zipato rfid aktiviere, wird nur noch die eingangstür scharf gestellt keine anderen… und push geht nicht mehr. nur der alarmanruf über die fritzbox zu meinem handy klappt…
Konnte bisher keine Probleme feststellen. Push geht und alle Sensoren werden geschärft. Hast du die neuste Version im Einsatz?
Ja die 4.140 Version. Davor 4.130 gehabt.
Ich sehe gerade folgende Info:
[DEBUG] 10:10:03: RFID-Szene 3.1 (Official) gestartet.
[DEBUG] 10:10:03: Status Away gesetzt.
[DEBUG] 10:10:03: Sensoren werden scharf geschaltet.
[DEBUG] 10:10:03: line 79: attempt to concatenate local 'sensorroom' (a nil value)
[DEBUG] 12:14:48: RFID-Szene 3.1 (Official) gestartet.
Line 79 wäre:
fibaro:debug(‘ACHTUNG: ’ … sensorname … ’ im Raum: ’ … sensorroom … ’ nicht sicher. Sende Push.’)
Hier noch der komplette Code:
131 value
-- notwendige IDs
local sensorID = {141, 40, 42, 46, 48, 50, 52, 54, 56, 58, 60, 62, 64} -- IDs der Sensoren
local phoneID = {152, 36} -- IDs der Handys
local doorlockID = {} -- IDs der doorlocks
-- zusätzliche Optionen
local own_action = false -- eigene Aktionen ausführen; Funktionen müssen befüllt werden
local disarmed_bug = false -- Firmware Bug umgehen
-- eigene Funktionen
function actionsafterArmed()
  fibaro:debug('Führe eigene Funktionen nach dem Schärfen aus')
function actionsafterDisarmed()
  fibaro:debug('Führe eigene Funktionen nach dem Entschärfen aus')
-- AB HIER NICHTS MEHR ÄNDERN
local rfid_value_status = ''
function armedcheckSensorID(array)
  for j=1, #sensorID do
    if sensorID[j] ~= nil then
      if (tonumber(fibaro:getValue(sensorID[j], 'armed')) ~= 0) then
          return false
  return true
-- Funktion für die Öffnung der Tür
function openDoor()
    if (doorlockID[0] ~= nil) then
    fibaro:debug('Türschlösser werden geöffnet.')
    for j=0, #doorlockID do
     if doorlockID[j] ~= nil then
       fibaro:call(doorlockID[j],'unsecure')
-- Funktion zum Versenden der Push
function sendPush(text)
 if (phoneID[1] ~= nil) then
  for i=1, #phoneID do
     if phoneID[i] ~= nil then
       fibaro:debug('Versende Push an ID ' ..phoneID[i])
       fibaro:call(phoneID[i],'sendPush', text, 'alarm')
function setArmedStatus(set_status)
  if set_status then
    fibaro:debug('Sensoren werden scharf geschaltet.')
    for k=1, #sensorID do
     if sensorID[k] ~= nil then
      if (tonumber(fibaro:getValue(sensorID[k], 'value')) == 0) then
       fibaro:call(sensorID[k], 'setArmed', '1')
       local sensorname = fibaro:getName(sensorID[k])
       local sensorroom = fibaro:getRoomNameByDeviceID(sensorID[k])
     fibaro:debug('ACHTUNG: ' .. sensorname .. ' im Raum: ' .. sensorroom .. ' nicht sicher. Sende Push.')
       sendPush('ACHTUNG: ' .. sensorname .. ' im Raum: ' .. sensorroom .. ' nicht sicher.')
    fibaro:debug('Sensoren werden entschärft.')
      if (disarmed_bug) then
       setArmed(sensorID[j])
       fibaro:call(sensorID[j], 'setArmed', '0')
function setArmed(deviceId)
  local dev = api.get('/devices/' .. deviceId)
  dev.properties.armed = false
  api.put('/devices/' .. deviceId, dev)
-- Funktion zum Anlegen einer Globalen Variablen
function globalVar(var,val)
  local http = net.HTTPClient()
  http:request("http://127.0.0.1:11111/api/globalVariables", {
    options = {
    method = 'POST',
    headers = {},
    data = '{"name":"'..var..'","value":"'..val..'"}',
    timeout = 10000
  success = function(response)
            local result = response.data;
              fibaro:debug('Status: ' ..response.status.. ' - Variable wurde angelegt')
              fibaro:debug('Error: ' ..response.status.. ' - Zugriff verweigert')
            end,
  error = function(err)
          fibaro:debug('[ERROR] ' .. err)
if (trigger['type'] == 'property') then
 fibaro:debug('RFID-Szene 3.1 (Official) gestartet.')
 local rfid_ID = tonumber(trigger['deviceID'])
 local rfid_value = tonumber(fibaro:getValue(rfid_ID, 'value'))
  if (rfid_value == 1) then
    rfid_value_status = 'Away'
    Debug('red', 'Status ' ..rfid_value_status.. ' gesetzt.')
    setArmedStatus(true)
    if (fibaro:getGlobal('PresentState') ~= nil) then
     fibaro:debug('Benötigte Variable PresentState erkannt.')
     fibaro:setGlobal('PresentState', 'Away')
     fibaro:debug('Benötigte Variable PresentState NICHT erkannt. Wird erstellt.')
     globalVar('PresentState', 'Away')
    local delay = tonumber(fibaro:getValue(sensorID[1], "armDelay"))
      if (delay ~= 0) then
       fibaro:debug('Arm-Delay erkannt. Arm-Delay: ' ..delay)
       delay = delay + 1
       fibaro:sleep(delay*1000)
    if (not armedcheckSensorID(sensorID)) then
      if (own_action) then
        actionsafterArmed()
      sendPush('ALARMANLAGE aktiv!')
  elseif (rfid_value == 0) then
    rfid_value_status = 'Home'
    Debug('green', 'Status ' ..rfid_value_status.. ' gesetzt.')
    setArmedStatus(false)
     fibaro:setGlobal('PresentState', 'Home')
     globalVar('PresentState', 'Home')
    if (armedcheckSensorID(sensorID)) then
     sendPush('ALARMANLAGE inaktiv!')
     openDoor()
    fibaro:debug('Szene manuell gestartet. Widget-Support deaktiviert.')
    fibaro:debug('Hier werden noch weitere Funktionen folgen.')
Ich habe gerade gesehen, dass sich der Sensor 46 nicht mehr finden lässt. Nur ein unbekannter 45er… Da muss ich gleich mal nachschauen…
Da hast du ja deinem Fehler ?
