Frage Anruf bei Alarm
Ich habe die neue Fritzbox 7590.
Jetzt habe ich das Scipt:
-- These variables must be set
local URL="192.168.178.1" --IP Fritz!Box
local USERNAME="xxxx" --Username
local PASSWORD="xxxxx" --Password
local NUMBERTODIAL="xxxxx" --Number to dial
local NUMBERTODIAL2="" --Number to dial2
local PAUSE=20 --Sleeping Time for hanging up
------------------ BIT Library -------------------------------
local function check_int(n)
 -- checking not float
 if(n - math.floor(n) > 0) then
  error("trying to use bitwise operation on non-integer!")
local function tbl_to_number(tbl)
 local n = #tbl
 local rslt = 0
 local power = 1
 for i = 1, n do
  rslt = rslt + tbl[i]*power
  power = power*2
 return rslt
local function expand(tbl_m, tbl_n)
 local big = {}
 local small = {}
 if(#tbl_m > #tbl_n) then
  big = tbl_m
  small = tbl_n
  big = tbl_n
  small = tbl_m
 -- expand small
 for i = #small + 1, #big do
  small[i] = 0
local to_bits = function () end
local function bit_not(n)
 local tbl = to_bits(n)
 local size = math.max(#tbl, 32)
 for i = 1, size do
  if(tbl[i] == 1) then
   tbl[i] = 0
   tbl[i] = 1
 return tbl_to_number(tbl)
to_bits = function (n)
 check_int(n)
 if(n < 0) then
  -- negative
  return to_bits(bit_not(math.abs(n)) + 1)
 -- to bits table
 local tbl = {}
 local cnt = 1
 while (n > 0) do
  local last = n%2
  if(last == 1) then
   tbl[cnt] = 1
   tbl[cnt] = 0
  n = (n-last)/2
  cnt = cnt + 1
 return tbl
local function bit_or(m, n)
 local tbl_m = to_bits(m)
 local tbl_n = to_bits(n)
 local tbl = {}
 local rslt = math.max(#tbl_m, #tbl_n)
 for i = 1, rslt do
  if(tbl_m[i]== 0 and tbl_n[i] == 0) then
   tbl[i] = 0
   tbl[i] = 1
local function bit_and(m, n)
 local tbl = {}
 for i = 1, rslt do
  if(tbl_m[i]== 0 or tbl_n[i] == 0) then
   tbl[i] = 0
   tbl[i] = 1
local function bit_xor(m, n)
 local tbl = {}
 for i = 1, rslt do
  if(tbl_m[i] ~= tbl_n[i]) then
   tbl[i] = 1
   tbl[i] = 0
 --table.foreach(tbl, print)
local function bit_rshift(n, bits)
 check_int(n)
 local high_bit = 0
 if(n < 0) then
  -- negative
  n = bit_not(math.abs(n)) + 1
  high_bit = 2147483648 -- 0x80000000
 for i=1, bits do
  n = n/2
  n = bit_or(math.floor(n), high_bit)
 return math.floor(n)
-- logic rightshift assures zero filling shift
local function bit_logic_rshift(n, bits)
 check_int(n)
 if(n < 0) then
  -- negative
 for i=1, bits do
  n = n/2
local function bit_lshift(n, bits)
 check_int(n)
 if(n < 0) then
  -- negative
 for i=1, bits do
  n = n*2
 return bit_and(n, 4294967295) -- 0xFFFFFFFF
local function bit_xor2(m, n)
 local rhs = bit_or(bit_not(m), bit_not(n))
 local lhs = bit_or(m, n)
 local rslt = bit_and(lhs, rhs)
 return rslt
-- An MD5 mplementation in Lua, requires bitlib (hacked to use LuaBit from above, ugh)
-- 10/02/2001 jcw@equi4.com
local md5={ff=tonumber('ffffffff',16),consts={}}
string.gsub([[ d76aa478 e8c7b756 242070db c1bdceee
    f57c0faf 4787c62a a8304613 fd469501
    698098d8 8b44f7af ffff5bb1 895cd7be
    6b901122 fd987193 a679438e 49b40821
    f61e2562 c040b340 265e5a51 e9b6c7aa
    d62f105d 02441453 d8a1e681 e7d3fbc8
    21e1cde6 c33707d6 f4d50d87 455a14ed
    a9e3e905 fcefa3f8 676f02d9 8d2a4c8a
    fffa3942 8771f681 6d9d6122 fde5380c
    a4beea44 4bdecfa9 f6bb4b60 bebfbc70
    289b7ec6 eaa127fa d4ef3085 04881d05
    d9d4d039 e6db99e5 1fa27cf8 c4ac5665
    f4292244 432aff97 ab9423a7 fc93a039
    655b59c3 8f0ccc92 ffeff47d 85845dd1
    6fa87e4f fe2ce6e0 a3014314 4e0811a1
    f7537e82 bd3af235 2ad7d2bb eb86d391
    67452301 efcdab89 98badcfe 10325476 ]],"(%w+)", function (s) table.insert(md5.consts, tonumber(s,16)) end)
    --67452301 efcdab89 98badcfe 10325476 ]],"(%w+)", function (s) tinsert(md5.consts,tonumber(s,16)) end)
function md5.transform(A,B,C,D,X)
  local f=function (x,y,z) return bit_or(bit_and(x,y),bit_and(-x-1,z)) end
  local g=function (x,y,z) return bit_or(bit_and(x,z),bit_and(y,-z-1)) end
  local h=function (x,y,z) return bit_xor(x,bit_xor(y,z)) end
  local i=function (x,y,z) return bit_xor(y,bit_or(x,-z-1)) end
  local z=function (f,a,b,c,d,x,s,ac)
        a=bit_and(a+f(b,c,d)+x+ac,md5.ff)
        -- be *very* careful that left shift does not cause rounding!
        return bit_or(bit_lshift(bit_and(a,bit_rshift(md5.ff,s)),s),bit_rshift(a,32-s))+b
  local a,b,c,d=A,B,C,D
  local t=md5.consts
  a=z(f,a,b,c,d,X[ 0], 7,t[ 1])
  d=z(f,d,a,b,c,X[ 1],12,t[ 2])
  c=z(f,c,d,a,b,X[ 2],17,t[ 3])
  b=z(f,b,c,d,a,X[ 3],22,t[ 4])
  a=z(f,a,b,c,d,X[ 4], 7,t[ 5])
  d=z(f,d,a,b,c,X[ 5],12,t[ 6])
  c=z(f,c,d,a,b,X[ 6],17,t[ 7])
  b=z(f,b,c,d,a,X[ 7],22,t[ 8])
  a=z(f,a,b,c,d,X[ 8], 7,t[ 9])
  d=z(f,d,a,b,c,X[ 9],12,t[10])
  c=z(f,c,d,a,b,X[10],17,t[11])
  b=z(f,b,c,d,a,X[11],22,t[12])
  a=z(f,a,b,c,d,X[12], 7,t[13])
  d=z(f,d,a,b,c,X[13],12,t[14])
  c=z(f,c,d,a,b,X[14],17,t[15])
  b=z(f,b,c,d,a,X[15],22,t[16])
  a=z(g,a,b,c,d,X[ 1], 5,t[17])
  d=z(g,d,a,b,c,X[ 6], 9,t[18])
  c=z(g,c,d,a,b,X[11],14,t[19])
  b=z(g,b,c,d,a,X[ 0],20,t[20])
  a=z(g,a,b,c,d,X[ 5], 5,t[21])
  d=z(g,d,a,b,c,X[10], 9,t[22])
  c=z(g,c,d,a,b,X[15],14,t[23])
  b=z(g,b,c,d,a,X[ 4],20,t[24])
  a=z(g,a,b,c,d,X[ 9], 5,t[25])
  d=z(g,d,a,b,c,X[14], 9,t[26])
  c=z(g,c,d,a,b,X[ 3],14,t[27])
  b=z(g,b,c,d,a,X[ 8],20,t[28])
  a=z(g,a,b,c,d,X[13], 5,t[29])
  d=z(g,d,a,b,c,X[ 2], 9,t[30])
  c=z(g,c,d,a,b,X[ 7],14,t[31])
  b=z(g,b,c,d,a,X[12],20,t[32])
  a=z(h,a,b,c,d,X[ 5], 4,t[33])
  d=z(h,d,a,b,c,X[ 8],11,t[34])
  c=z(h,c,d,a,b,X[11],16,t[35])
  b=z(h,b,c,d,a,X[14],23,t[36])
  a=z(h,a,b,c,d,X[ 1], 4,t[37])
  d=z(h,d,a,b,c,X[ 4],11,t[38])
  c=z(h,c,d,a,b,X[ 7],16,t[39])
  b=z(h,b,c,d,a,X[10],23,t[40])
  a=z(h,a,b,c,d,X[13], 4,t[41])
  d=z(h,d,a,b,c,X[ 0],11,t[42])
  c=z(h,c,d,a,b,X[ 3],16,t[43])
  b=z(h,b,c,d,a,X[ 6],23,t[44])
  a=z(h,a,b,c,d,X[ 9], 4,t[45])
  d=z(h,d,a,b,c,X[12],11,t[46])
  c=z(h,c,d,a,b,X[15],16,t[47])
  b=z(h,b,c,d,a,X[ 2],23,t[48])
  a=z(i,a,b,c,d,X[ 0], 6,t[49])
  d=z(i,d,a,b,c,X[ 7],10,t[50])
  c=z(i,c,d,a,b,X[14],15,t[51])
  b=z(i,b,c,d,a,X[ 5],21,t[52])
  a=z(i,a,b,c,d,X[12], 6,t[53])
  d=z(i,d,a,b,c,X[ 3],10,t[54])
  c=z(i,c,d,a,b,X[10],15,t[55])
  b=z(i,b,c,d,a,X[ 1],21,t[56])
  a=z(i,a,b,c,d,X[ 8], 6,t[57])
  d=z(i,d,a,b,c,X[15],10,t[58])
  c=z(i,c,d,a,b,X[ 6],15,t[59])
  b=z(i,b,c,d,a,X[13],21,t[60])
  a=z(i,a,b,c,d,X[ 4], 6,t[61])
  d=z(i,d,a,b,c,X[11],10,t[62])
  c=z(i,c,d,a,b,X[ 2],15,t[63])
  b=z(i,b,c,d,a,X[ 9],21,t[64])
  return A+a,B+b,C+c,D+d
-- convert little-endian 32-bit int to a 4-char string
local function leIstr(i)
  local f=function (s) return string.char(bit_and(bit_rshift(i,s),255)) end
  return f(0)..f(8)..f(16)..f(24)
  -- convert raw string to big-endian int
  local function beInt(s)
    local v=0
    for i=1,string.len(s) do v=v*256+string.byte(s,i) end
    return v
  -- convert raw string to little-endian int
  local function leInt(s)
    local v=0
    for i=string.len(s),1,-1 do v=v*256+string.byte(s,i) end
    return v
  -- cut up a string in little-endian ints of given size
  local function leStrCuts(s)
    local o,r=1,{}
    for i=1,16 do
      table.insert(r,leInt(string.sub(s,o,o+4-1)))
      o=o+4
    return r
function md5.Calc(s)
  local msgLen=string.len(s)
  local padLen=56- msgLen % 64
  if msgLen % 64 > 56 then padLen=padLen+64 end
  if padLen==0 then padLen=64 end
  s=s..string.char(128)..string.rep(string.char(0),padLen-1)
  s=s..leIstr(8*msgLen)..leIstr(0)
  assert(string.len(s) % 64 ==0)
  local t=md5.consts
  local a,b,c,d=t[65],t[66],t[67],t[68]
  for i=1,string.len(s),64 do
    local X=leStrCuts(string.sub(s,i,i+63))
    assert(#X==16)
    X[0]=table.remove(X,1) -- zero based!
    a,b,c,d=md5.transform(a,b,c,d,X)
  local swap=function (w) return beInt(leIstr(w)) end
  return string.format("%08x%08x%08x%08x",swap(a),swap(b),swap(c),swap(d))
------------ Library for encoding UTF8 to UTF16LE
local LE = 0x1
local DE = 0x2
local BYTE_1_HEAD = 0x00		-- 0000 0000
local BYTE_2_HEAD = 0xC0		-- 1100 0000
local BYTE_3_HEAD = 0xE0		-- 1110 0000
local BYTE_TAIL_HEAD = 0x80		-- 1000 0000
local BYTE_1_MASK = 0x80		-- 1000 0000
local BYTE_2_MASK = 0xE0		-- 1110 0000
local BYTE_3_MASK = 0xF0		-- 1111 0000
local BYTE_TAIL_MASK = 0x3F		-- 0011 1111
local Format_char = function(b)
	return string.format("%c", b)
function UTF8To16(utf8, order)
	assert(type(utf8) == 'string')
	local result, tmp = {}, {}
	local i, b1, b2, b3, high, low = 1, 0, 0, 0, 0, 0
	local len = #utf8
	while i <= len do
		b1 = string.byte(utf8, i)
		if bit_and(b1, BYTE_1_MASK) == BYTE_1_HEAD then		-- 0### ####
			low = Format_char(b1); high = "\0"; i = i + 1
		elseif bit_and(b1, BYTE_2_MASK) == BYTE_2_HEAD then 	-- 110# ####
			b2 = string.byte(utf8, i + 1)
			high = Format_char(bit_rshift(bit_and(bit_not(BYTE_2_MASK), b1), 2))
			low =  Format_char(bit_or(bit_and(BYTE_TAIL_MASK, b2), bit_lshift(b1, 6)))
			i = i + 2
		elseif bit_and(b1, BYTE_3_MASK) == BYTE_3_HEAD then	-- 1110 ####
			b2, b3 = string.byte(utf8, i + 1, i + 2)
			high = Format_char(bit_or(bit_lshift(b1, 4), bit_rshift(bit_and(BYTE_TAIL_MASK, b2), 2)))
			low = Format_char(bit_or(bit_lshift(b2, 6), bit_and(BYTE_TAIL_MASK, b3)))
			i = i + 3
		if order == DE then low, high = high, low end
		table.insert(result, low .. high)
	return table.concat(result)
------------------------ Web Requests ------------------------
local function getMethod(requestUrl, successCallback, errorCallback)
  local http = net.HTTPClient()
  http:request(requestUrl, {
      options = {
        method = 'GET'
      success = successCallback,
      error = errorCallback
local function postMethod(requestUrl, data, successCallback, errorCallback)
      options = {
        headers = {["content-Type"] = "application/x-www-form-urlencoded"},
        method = 'POST',
        redirect = false,
        data = data,
        timeout = 5000
function tprint (tbl, indent)
  if not indent then indent = 0 end
  for k, v in pairs(tbl) do
    formatting = string.rep("  ", indent) .. k .. ": "
    if type(v) == "table" then
      print(formatting)
      tprint(v, indent+1)
    elseif type(v) == 'boolean' then
      print(formatting .. tostring(v))
      print(formatting .. v)
getMethod("http://"..URL.."/", function(resp)
  if resp.status == 200 then
      print('Could connect to FritzBox, status ' .. resp.status)
      print('Getting challenge key');
      local challenge = string.match(resp.data, '"challenge":"([%x ]+)"');
      if challenge==nil then
        fibaro:debug('Could not get challenge');
      print(challenge);
      x=challenge.."-"..PASSWORD;
      x=UTF8To16(x,LE);
      md5sum=md5.Calc(x);
      print('MD5Sum: '..md5sum..' of string "'..x..'"');
      response=challenge.."-"..md5sum;
      postMethod("http://"..URL.."/login_sid.lua",'response='..response..'&username='..USERNAME, function(resp)
          if resp.status==200 then
            print('Login and forward successfully: '..resp.status);
            local sid = string.sub(resp.data, 57, 72);
            print('SID: >'..sid..'<');
			if sid == "" or sid==nil then
               print('Could not get SID');
               print('Headers:');
               tprint(resp,0);
               fibaro:debug('Aborting');
            end;
            getMethod("http://"..URL.."/fon_num/fonbook_list.lua?sid="..sid.."&dial="..NUMBERTODIAL.."&xhr=1", function(resp)
                  	print('Called number, Waiting for '..PAUSE..' seconds to hangup');
                    fibaro:sleep(PAUSE*1000);
                  	getMethod("http://"..URL.."/fon_num/fonbook_list.lua?sid="..sid.."&hangup=&xhr=1", nil, nil);
                    fibaro:sleep(3*1000);
                    getMethod("http://"..URL.."/fon_num/fonbook_list.lua?sid="..sid.."&dial="..NUMBERTODIAL2.."&xhr=1", function(resp)
                            print('Calling failed');
                    end,
                    function(err)
                        print('Calling error ' .. err);
                    tprint(resp,0);
			end,
  			function(err)
                tprint(resp,0);
            print('Post failed not 303 but '..resp.status);
        end,
        function(err)
          print('Error ' .. err);
    print('Login failed: '..resp.status);
end,
function(err)
      print('error ' .. err)
Leider bekomme ich folgenden Fehler:
 [DEBUG] 14:25:04: Could connect to FritzBox, status 200
[DEBUG] 14:25:04: Getting challenge key
[DEBUG] 14:25:04: 44f67939
[DEBUG] 14:25:04: MD5Sum: e1810a8aaa88dd32d88828b948f1723c of string "44f67939-xxxxxxx"
[DEBUG] 14:25:04: Login and forward successfully: 200
[DEBUG] 14:25:04: SID: >96038dc97c336281<
[DEBUG] 14:25:05: Called number, Waiting for 20 seconds to hangup
Woran kann das liegen? Ich habe die Zugangsdaten der neuen Fritzbox angepasst.
Hi,was macht dieser Code bei dem Anruf? was würdest du hören?
bei der Ausgabe soll die Stelle mit Checksum falsch sein? die Leistungen sind doch alle mit „success“.
komischerwei hängt diese Seite auf Siio extrem bei mir, was es erschwert den code zu lesen.
Es geht eigentlich nur darum, dass ich einen Anruf erhalte, wenn der Alarm ausgelöst wurde. Push bekomme ich zwar auch, aber das Handy hat ja nicht immer inet.
Ich habe im Handy die Nummer als „Alarm Haus“ hinterlegt. Es wird soweit nichts gesagt wenn ich den Anruf annehme. Es geht mir nur um die Info das ich reagieren kann. Eventuell kann man es auch anders lösen.
hat hier jemand einen Tipp?
Wenn es mit der neuen Fritzbox / OS nicht klappt, müsste ich zur SMS wechseln…
Hab das Script nicht aber Log sieht gut aus.(200)
Ist die Nummer wählbar?
Was genau meinst du mit „Ist die Nummer wählbar?“ Die Nummer ist richtig hinterlegt. Habe ich drei mal kontrolliert. 01514xxxxx
Trag mal versuchsweise auch deine Nummer bei NUMBERTODIAL2= ein.
solltest dann im log 1. Nummer 20 sec Pause und 2. Nummer bekommen.
Die Fritzbox hat zwei analoge Anschlüsse, kann sein das du den anderen Port belegt hast.
Wenns mit der 2. Nummer geht, kannst ja die 1. wieder austragen.
werde ich nachher mal versuchen.
ich habe nur 1 analoges Telefon direkt angeschlossen. Kein weiteres. auch nur 1 Nummer konfiguriert.
ich habe ähnliches Problem wie jojothan. vor einiger Zeit bin ich von der 7390 auf die 7490 umgestiegen. Damals hatte ich auf der FritzBox noch eine 6er FW. Seit einem Update auf Version 7.X erhalte ich keinen Anruf mehr, jedoch den ähnlichen Debug wie jojothan. Es scheint augenscheinlich alles in Ordnung zu sein, jedoch wird nicht gewählt. Kann uns bitte jemand helfen?
Danke!
[DEBUG] 21:33:16: Could connect to FritzBox, status 200
[DEBUG] 21:33:16: Getting challenge key
[DEBUG] 21:33:16: 8d863a31
[DEBUG] 21:33:16: MD5Sum: 8a4fdb29ad43859e7cd5e707905785ce of string "8d863a31-XXXXX"
[DEBUG] 21:33:17: Login and forward successfully: 200
[DEBUG] 21:33:17: SID: >df8050bcbXXXX3e<
[DEBUG] 21:33:18: Called number, Waiting for 30 seconds to hangup
[DEBUG] 21:33:54: Called number, Waiting for 30 seconds to hangup
Peter
Ich habe durch weitere Suche die Lösung hier im Forum gefunden.
Wie Alex schreibt wurde die Adresse in der Fritzbox von „fonbook“ zu „foncalls“ geändert. Die Lösung in den Kommentaren kann ich als funktionell bestätigen. Bei mir im Script kam diese allerdings 4x vor.
Hier der Link: Anruf über eure Fritz!Box und euer Fibaro HomeCenter 2 – Dein Smart Home Blog
Gruß Peter
Hallo zusammen.
Wie ist das mit dem Script für einen HC3?
Ich habe zwar Leihenhaft versucht das Script zu laden, alles was Nötig ist angegeben,
Alle Aufrufe von Fibaro: nach Fibaro. geändert wie auch die erwähnte „fonbook“ zu „foncalls“ geändert.
Dann Manuel gestartet und folgende Fehlermeldung erhalten !
[15.04.2020] [11:19:53] [ERROR] [SCENE225]: (load):408: attempt to index a nil value (global ‚net‘)
Gegebenheiten :
Fritzbox ist die 7590 mit der Version 07.12
HC3 mit der Version 5.030.45
Hallo Peter,
mit der von dir zitierten Änderung hat’s bei mir auch wieder funktioniert,
allerdings nicht mehr bei OS 07.21, da gibt es offensichtlich schon wieder Änderungen.
Die Fehlermeldung : Could not get challenge
Ein Rene Kegel schreibt (in der Diskussion, zu der dein Link führt), es gäbe ein neues Script, mit dem es wieder ginge, aber er schreibt leider nicht wo.
Kann man den Autor Alex irgendwie erreichen?
hi @muc, schau mal bei https://forum.fibaro.com/topic/19611-because-sms-is-not-working-maybe-calling-with-help-of-fritzbox-is-enough/page/6/
da mein HC2 weggepackt ist, weiß ich nicht mehr welches Skript bei welcher Version läuft.
Hallo Sven,
vielen Dank! Das ist es.
