Version 4.130
This update features migration process from version 3.600, reconfiguring every device, adjusting them for changes which took place in the system. This will assure a possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please, refer to the message that appears in the interface and Notification Center for further instructions after finishing upgrade.
Important!
Updating from version 3.600 may take up to 30 minutes. Do not restart controller during update process.
New improvements:
- Refurbished layout of Heating Panel - simplified process of creating heating schedule, UI improvements in heating zones list, possibility to copy the daily schedule, possibility to set schedule intervals for all week.
- Extended door lock support - support for the PIN codes available from the device, added support for the PIN codes in Block Scenes and Magic Scenes.
Resolved issues:
- Error in using the AEON Labs LED Bulb.
- Stella Z - template does not show the temperature end point.
- Error after editing location in Location Panel.
- Error 503 during moving section.
- Minor graphic fixes.
