ich erhalte immer einen Kommunikationsfehler.
Hier mal ein Log aus dem AWS:
2017-03-07
16:24:44
START RequestId: 926edd1d-0352-11e7-a615-276beaf80744 Version: $LATEST
16:24:44
Syntax error in module ‚index‘: SyntaxError at exports.runInThisContext (vm.js:53:16) at Module._compile (module.js:373:25) at Object.Module._extensions..js (module.js:416:10) at Module.load (module.js:343:32) at Function.Module._load (module.js:300:12) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object.<anonymous> (/var/task/index.
16:24:44
END RequestId: 926edd1d-0352-11e7-a615-276beaf80744
16:24:44
REPORT RequestId: 926edd1d-0352-11e7-a615-276beaf80744 Duration: 4.32 ms Billed Duration: 100 ms Memory Size: 512 MB Max Memory Used: 30 MB
16:24:44
START RequestId: 92c2c962-0352-11e7-a9b3-67911b5eedf8 Version: $LATEST
16:24:44
Syntax error in module ‚index‘: SyntaxError at Module._compile (module.js:373:25) at Object.Module._extensions..js (module.js:416:10) at Module.load (module.js:343:32) at Function.Module._load (module.js:300:12) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object.<anonymous> (/var/task/index.js:8:16) at Module._compile (module.js:409
16:24:44
END RequestId: 92c2c962-0352-11e7-a9b3-67911b5eedf8
16:24:44
REPORT RequestId: 92c2c962-0352-11e7-a9b3-67911b5eedf8 Duration: 0.53 ms Billed Duration: 100 ms Memory Size: 512 MB Max Memory Used: 30 MB
Hat jemand eine Idee?
Gruß Andreas
