Klar gerne. Hier das ganze Skript
264 value
266 value
TimeOfDay
PresentState
--[[ Change - XXX value - above. One for motion sensor, one for Light sensor.
TimeOfDay global variable and lux make sure that the scene
will be triggered when you are already in the room and something changes.
Set your settings below, lights and add extra functions
This code is developed by Control Living. You can use this free of charge.
Feel free to suggest changes or contact when having problems.
Version 1.6.4
-----------------------YOUR LIGHT SETTINGS--------------------------
motionSensorID = {264}; -- change id for your motion sensor.
LuxSensorID = {266}; -- change id for your light sensor.
--Enter the name of your Global variable. WITHOUT IT, THE SCENE DOES NOT WORK. Capital sensitive!
sleepState = "SleepState"; --Sleep globalstate variable.
timeOfDay = "TimeOfDay"; --Time of Day Global variable.
presentState = "PresentState"; --Present state Global variable.
--Enter the values of your global variables stated above. If not using, copy the name in front of the "YourValueName"
sleepStateMapping = {Sleeping="Sleeping", Awake="Awake"};
timeOfDayMapping = {Morning="Morning", Day="Day", Evening="Evening", Night="Night"};
presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"};
-- Set the lux value for which the lights have to be turned on.
-- If you don't want to use the MinLux then just set it to: 65535
minLuxMorning = 50;
minLuxDay = 100;
minLuxEvening = 50;
minLuxNight = 0;
Now the most important part:
Here you can enter what light, for how long and at what value has to be turned on.
Leave empty brackets for no lights.
To set the light value without timer use 2 parameters: {LightID, "VALUE"}
To set the light value with timer use 3 parameters: {LightID, "VALUE", timeInSeconds }
To set the light value with the
automatic lights virtual device. use 4 parameters: {LightID, "VALUE", "timeInSeconds", VirtualDeviceSliderID} --]]
lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping.
lightsMorning = {{id=209, setValue="turnOn", onTime=180}};
lightsDay = {{id=209, setValue="turnOn", onTime=300}};
lightsEvening = {{id=209, setValue="turnOn", onTime=30}};
lightsNight = {{id=0, setValue="turnOn", onTime=30}};
--setValue={R="255",G="255",B="255",W="255"}
--Manual Override, the time that lights will not be turned ON again after manually turning them off.
OverrideFor = 90;
dimmDownTime = 10;
-------------------------EXTRA FEATURES-----------------------------
extraMorningFunc = function()
-- Add your extra code here. If you want some checks or maybe run a virtual device button.
--This code is always triggered if there is motion.
-- movieLights = {{180, "10"},{181, "10"} };
--if (xbmc == "playing" ) then CallLightArray(movieLights);
ExtraDebug("Extra morning function called");
extraDayFunc = function()
ExtraDebug("Extra day function called");
extraEveningFunc = function()
ExtraDebug("Extra evening function called");
extraNightFunc = function()
ExtraDebug("Extra night function called");
extraLightTriggerChecks = function()
--add extra checks here. and return the total true or false value.
--if returning false the lights will not be triggered.
-- for instance: return ( (pcTurnedOff == true ) and (xbmc ~= "Empty") );
-- return true to enable lights to turn on
return true;
extraOffChecks = function()
--return true to keep lights on.
return false;
----------------------ADVANCES SETTINGS-----------------------------
local showStandardDebugInfo = true; -- Debug shown in white
local showExtraDebugInfo = true; -- Debug shown in orange
-- DO NOT CHANGE THE CODE BELOW --
--UPDATE FROM HERE
--private variables
startSource = fibaro:getSourceTrigger();
keepLightsOn = false;
timerRunning = false;
previousLights = nil;
version = "1.6.4";
SavedState = {
homeStatus = "",
sleepState = 0,
timeOfDay = "",
lux = 0,
motion = 0,
startTime = 0
CurrentState = {
homeStatus = "",
sleepState = "",
timeOfDay = "",
lux = 0,
motionState = 0,
currentLightArray = {}
--Making sure that only one instance of the scene is running.
fibaro:sleep(50); --sleep to prevent all instances being killed.
if (showExtraDebugInfo) then
Debug( "grey", "Abort, Scene count = " .. fibaro:countScenes());
--------------------------EXECUTION----------------------------------
SetCurrentStatus = function ()
ExtraDebug("Updating current variable statuses");
CurrentState.homeStatus = GetPresentState();
CurrentState.timeOfDay = GetTimeOfDay();
CurrentState.sleepState = GetSleepState();
CurrentState.lux = GetAverageLuxValue();
CurrentState.motionState = GetCurrentMotionStatus();
SaveCurrentStatus = function()
ExtraDebug("Saving current variable statuses");
SavedState.homeStatus = CurrentState.homeStatus;
SavedState.timeOfDay = CurrentState.timeOfDay;
SavedState.sleepState = CurrentState.sleepState;
SavedState.lux = CurrentState.lux;
SavedState.motion = CurrentState.motionState;
CheckStatusChanges = function ()
ExtraDebug("Status change check");
if (CurrentState.homeStatus ~= SavedState.homeStatus ) or (CurrentState.timeOfDay ~= SavedState.timeOfDay ) then
SceneTriggered();
SaveCurrentStatus();
-- if we still have a motion then reset timer.
if (CurrentState.motionState ~= 0 or extraOffChecks() ) then
ExtraDebug( "Resetting time" );
SavedState.startTime = os.time();
--any other case, we are not resetting the timer.
LightsOff = function ( lightArray )
local stillLightsOn = 0;
local currentTime = os.time();
for i = 1,#lightArray do
if ( lightArray[i].onTime ~= nil) then
lightItem = lightArray[i];
lightItem.OffMode = CheckManualOverrideItem( lightItem );
--local
if ( lightItem.OffMode == "ManualOverride" ) then
ExtraDebug("Manual override for light: [" .. lightItem.id .. "]" .. lightItem.name .. " active, not turning on");
goto continue;
--On till:
local timeL = SavedState.startTime + (lightItem.onTime);
local timeLeft = timeL - currentTime;
if (timeLeft >= 0 ) then ExtraDebug("Time left for: [" .. lightItem.id .. "]" .. lightItem.name .. ": " .. timeLeft .. " seconds" ); end
if ( timeLeft < dimmDownTime ) then
if ( lightItem.OffMode ~= "ManualOverride" ) then
lightItem.OffMode = "ByScene";
if ( (timeLeft <= 0) and (lightItem.currentValue ~= 0) ) then
fibaro:call(lightItem.id, "turnOff");
StandardDebug("Switch off light: [" .. lightItem.id .. "]'" .. lightItem.name .."'");
currentValueDiv = roundit(((lightItem.currentValue) / (dimmDownTime)), 0);
currentValueNew = (lightItem.currentValue - currentValueDiv);
if (currentValueNew <=0 ) then currentValueNew = 0; end
fibaro:call(lightItem.id, "setValue", tostring(currentValueNew));
stillLightsOn = stillLightsOn + 1;
elseif lightItem.OffMode=="ByScene" and ((lightItem.currentValue) < tonumber(lightItem.setValue) ) then
ExtraDebug("Turn light: " .. lightItem.id .. " back on");
turnLightOn(lightItem);
--fibaro:call(lightItem.id, "setValue", lightItem.setValue );
lightItem.OffMode = "";
lightItem.OffMode = "NoOverride";
::continue::
return stillLightsOn;
KeepLightsOnTimer = function ()
ExtraDebug("--------------- Timer running ---------------");
ExtraDebug("starting with while loop, to keep lights on");
sleepTime = 1000;
while ( keepLightsOn ) do
ExtraDebug("--------------- next timer run ---------------");
fibaro:sleep(sleepTime);
start_time = os.clock();
SetCurrentStatus();
currentLightArray = GetTimeOfDayLightArray();
UpdateLightValues(currentLightArray);
CheckStatusChanges();
stillLightsOn = LightsOff( currentLightArray );
if (stillLightsOn == 0 ) then
keepLightsOn = RunManualOverrideMode( currentLightArray );
end_time = os.clock()
elapsed_time = (end_time - start_time) * 1000;
sleepTime = 1000 - elapsed_time;
CheckManualOverrideItem = function( currentItem )
--ExtraDebug("Manual override check for: [" .. currentItem.id .. "]" .. currentItem.name);
if (currentItem.currentValue == 0 and currentItem.OffMode ~= "ByScene" ) then
ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " active" );
return "ManualOverride";
elseif (currentItem.currentValue ~= 0 and currentItem.OffMode == "ManualOverride" ) then
ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " cancelled" );
return "NoOverride";
return currentItem.OffMode; --returning current mode;
RunManualOverrideMode = function ( currentLightArray )
OverrideForAll = CheckIfAllInOverrideMode(currentLightArray);
if ( OverrideForAll ) then
ExtraDebug("-----------------Override Mode---------------");
OverrideTimer = os.time();
while ( OverrideForAll and (OverrideTimer + OverrideFor ) - os.time() > 0 ) do
ExtraDebug("Still in override for: " .. (OverrideTimer + OverrideFor ) - os.time() .. " seconds" );
fibaro:sleep(1000);
motion = GetCurrentMotionStatus();
if ( motion ~= 0 ) then
else return false;
-- if ( (OverrideTimer + OverrideFor ) - os.time() <= 0 ) then
--time has end. So not continue to run lights loop
-- return false;
-- end
if (OverrideForAll) then
return false; --run lights
else return true;
CheckIfAllInOverrideMode = function(currentLightArray)
OverrideForAll = 0;
for i = 1,#currentLightArray do
if ( CheckManualOverrideItem(currentLightArray[i]) == "ManualOverride" ) then
OverrideForAll = OverrideForAll +1;
return false;
if ( OverrideForAll ~= 0 and OverrideForAll == #currentLightArray ) then
return true;
return false;
RunTimer = function()
if ( keepLightsOn and not timerRunning ) then
ExtraDebug("Starting timer, not yet running");
timerRunning = true;
KeepLightsOnTimer();
ExtraDebug("Timer already running, returning");
----------------------Turn lights on functions------------------------
CallLightArray = function( lightArray )
if (#lightArray == 0 ) then
StandardDebug( "No lights set for " .. CurrentState.timeOfDay );
return;
if not ( CheckIfTable(lightArray, "lights" .. CurrentState.timeOfDay ) ) then return end
if not ( CheckIfTable(lightArray[i], "lights" .. CurrentState.timeOfDay ) ) then break end
if (lightItem.onTime ~= nil) then keepLightsOn = true; end
StandardDebug( "Lights set for: " .. CurrentState.timeOfDay );
turnLightOn = function( lightItem )
if (lightItem.lightType == "com.fibaro.multilevelSwitch" ) then
fibaro:call(lightItem.id, "setValue", lightItem.setValue);
StandardDebug( "Set: [" .. lightItem.id .. "]'" .. lightItem.name .. "' to Value: " .. lightItem.setValue );
elseif(lightItem.lightType == "com.fibaro.binarySwitch") then
fibaro:call(lightItem.id, "turnOn");
StandardDebug( "Turn: [" .. lightItem.id .. "]'" .. lightItem.name .. "' On");
elseif(lightItem.lightType == "com.fibaro.RGBW") then
--TODO addR=255,G=255,B=255,W=255}
local clrvalues =lightItem.setValue;
--fibaro:call(lightItem.id, "setColor", clrvalues.R, clrvalues.G, clrvalues.B, clrvalues.W)
CheckPreviousLights = function( NewLightArray )
if ( previousLights ~= nil ) then
for i = 1,#previousLights do
local lightItem = previousLights[i];
for i = 1,#NewLightArray do
local lightItem1 = NewLightArray[i];
inarray = false;
if ( lightItem.id == lightItem1.id ) then
inarray= true;
break
if not ( inarray ) then fibaro:call(lightItem.id, "turnOff"); end
previousLights = NewLightArray;
LightperDayPart = function( minLux, lightArray )
local newLuxValue = CurrentState.lux;
if ( CurrentState.homeStatus ~= presentStateMapping.Home ) then
ExtraDebug("Presentstate = not at home, so no lights");
return;
if ( extraLightTriggerChecks() ) then
if ( newLuxValue > minLux ) then
StandardDebug( "Sensor lux: " .. newLuxValue .. " higher then minValue: " .. minLux .. " : no action");
StandardDebug("Sensor lux: " .. newLuxValue .. " is lower then minValue: " .. minLux);
SetLightValues(lightArray);
CallLightArray( lightArray );
CheckPreviousLights( lightArray );
ExtraDebug("ExtraLightTriggerChecks failed, so no lights");
SceneTriggered = function()
if ( CurrentState.sleepState == sleepStateMapping.Sleeping ) then
LightperDayPart( 65535, lightsSleeping );
elseif ( CurrentState.timeOfDay == timeOfDayMapping.Morning ) then
extraMorningFunc();
LightperDayPart( minLuxMorning, lightsMorning );
elseif ( CurrentState.timeOfDay == timeOfDayMapping.Day ) then
extraDayFunc();
LightperDayPart( minLuxDay, lightsDay );
elseif ( CurrentState.timeOfDay == timeOfDayMapping.Evening ) then
extraEveningFunc();
LightperDayPart( minLuxEvening, lightsEvening );
elseif ( CurrentState.timeOfDay == timeOfDayMapping.Night ) then
extraNightFunc();
LightperDayPart( minLuxNight, lightsNight );
ErrorDebug( "No lights: " .. CurrentState.timeOfDay );
RunTimer();
SceneTriggeredByLights = function( st )
if (st == "off") then
ExtraDebug( "light turned off, sleep 4 sec" );
fibaro:sleep(4000);
elseif (st == "on") then
ExtraDebug( "light turned on, activating timer" );
fibaro:sleep(4000);
--TODO: add light to current array.
--keepLightsOn = true;
--RunTimer();
------------------------STATUS functions------------------------------
GetTimeOfDay = function ()
return LookupGlobal( timeOfDay, "TimeOfDay", "Day");
GetSleepState = function ()
return LookupGlobal( sleepState, "sleepState", "Awake");
GetPresentState = function ()
return LookupGlobal( presentState, "presentState", "Home");
LookupGlobal = function ( name, stateName, default )
local ps = fibaro:getGlobalValue( name );
if ( (ps ~= "") and (ps ~= nil ) ) then
ExtraDebug("returned " .. stateName .. ": " .. ps );
return ps;
ErrorDebug( stateName .. " variable not found");
return default;
lightsStatus = function ( id )
--check if lights are already on.
allLights = {lightsSleeping, lightsMorning, lightsDay, lightsEvening, lightsNight };
for i = 1,#allLights do
for iL = 1, #allLights[i] do
local lightItem = allLights[i][iL];
if ( lightItem.id == tonumber(id) ) then
if ( lightItem.currentValue == 0 ) then
return "off";
return "on";
ErrorDebug("Light status unknown");
return "Unknown";
GetTimeOfDayLightArray = function ()
return lightsSleeping;
return lightsMorning;
return lightsDay;
return lightsEvening;
return lightsNight;
GetCurrentMotionStatus = function()
local sensorbreached = 0;
if (CheckIfTable(motionSensorID, "motionSensorID") ) then
for i = 1,#motionSensorID do
if ( tonumber(fibaro:getValue(motionSensorID[i], "value")) > 0 ) then
sensorbreached = 1;
--if not a table, just return the value of the containing ID
sensorbreached = tonumber(fibaro:getValue(motionSensorID, "value"))
return sensorbreached;
GetAverageLuxValue = function()
local luxAverage = 0;
if (CheckIfTable(LuxSensorID, "LuxSensorID") ) then
if (#LuxSensorID == 1) then
return tonumber(fibaro:getValue(LuxSensorID[1], "value"));
for i = 1,#LuxSensorID do
luxAverage = luxAverage + tonumber(fibaro:getValue(LuxSensorID[i], "value"));
luxAverage = roundit( (luxAverage / #LuxSensorID), 0 );
luxAverage = tonumber(fibaro:getValue(LuxSensorID, "value"));
return luxAverage;
UpdateLightValues = function( currentArray )
for i = 1,#currentArray do
item = currentArray[i];
item.currentValue = tonumber(fibaro:getValue(item.id, "value"));
SetLightValues = function(currentArray)
item.name = tostring(fibaro:getName(item.id));
item.OffMode = "NoOverride";
if (item.name == nil) then item.name = "Unknown"; end
item.lightType = fibaro:getType(item.id);
--------------------Helper functions--------------------------------
CheckIfTable = function( array, arrayname )
local tableCheck = tostring( type( array ) );
if ( tableCheck ~= "table" ) then
ErrorDebug("Missing brackets for variable: '" .. arrayname .. "', please place extra brackts: { } around: " .. array .. ".");
return false;
return true;
function roundit(num, idp)
local mult = 10^(idp or 0)
return math.floor(num * mult + 0.5) / mult
idIsInList = function ( startSourceId, sensorList )
for i = 1,#sensorList do
if ( startSourceId == sensorList[i] ) then
return true;
return false;
--------------------Debugging Functions-----------------------------
StandardDebug = function ( debugMessage )
if ( showStandardDebugInfo ) then
Debug( "white", debugMessage);
ExtraDebug = function ( debugMessage )
if ( showExtraDebugInfo ) then
Debug( "orange", debugMessage);
ErrorDebug = function ( debugMessage )
Debug( "red", "Error: " .. debugMessage);
TestDebug = function (debugMessage )
Debug( "blue", "Testing: " .. debugMessage );
----------------------START OF THE SCENE----------------------------
SetCurrentStatus();
StandardDebug("Home status: " .. CurrentState.homeStatus );
StandardDebug("Motion status: " .. ( CurrentState.motionState == 0 and "No movement" or "movement"));
if (startSource["type"] == "property") then
startSourceID = tonumber(startSource['deviceID']);
triggerDebug = "Triggered by: " .. startSourceID;
if ( idIsInList( startSourceID, motionSensorID ) ) then
StandardDebug( triggerDebug .. " Motion sensor" );
if ( CurrentState.motionState > 0 ) then
SceneTriggered();
elseif ( idIsInList( startSourceID, LuxSensorID ) ) then
StandardDebug( triggerDebug .. " Lux sensor" );
ExtraDebug( "Lux value changed to: " .. CurrentState.lux );
SceneTriggered();
-- elseif ( idIsInList( startSourceID, walkDirections ) ) then
--StandardDebug( triggerDebug .. " Walk Direction sensor" );
--walkDirection( startSourceID );
StandardDebug( triggerDebug .. " Light switch" );
st = lightsStatus( startSourceID );
if (st == "Unknown") then
ErrorDebug( "Unknown light trigger" );
SceneTriggeredByLights( st );
-- Maybe we can change the light preset to make it more intelligent.
-- Maybe we can change the Lux preset to make it more intelligent.
elseif ( startSource["type"] == "global" ) then
StandardDebug( "Triggered by: " .. "global variable" );
SceneTriggered();
StandardDebug( "Triggered by: " .. startSource["type"] );
--Just run the Light Code, not checking for motion. Probably triggered manually.
if ( startSource["type"] == "other" ) then
SceneTriggered();
Debug( "green", "Smart Lights V" .. version .. " | by Control Living, Finished" );
Debug( "green", "-------------------------------------------------------" );
--fibaro:abort(); --otherwise scene will stay alive to long.
--UPDATE TILL HERE
