Device Inventory (HC3)
Eines meiner ältesten Scripte für das HC2 hab ich jetzt an das HC3 angepasst. Das braucht man nicht oft , aber der Mensch ist ja bekanntermaßen neugierig.
-- file: HC3-Device-inventory.lua
-- version: 0.1.1 HC-3
-- Works with version up to ...
-- purpose:This script shows the device inventory and prints the output to
-- the debug window.
-- Copyleft 08-2017 - 2021  {jwi}
local version   = "0.1.1"
local fc_lg = '<font color="lightgreen">'
local fc_o  = '<font color="orange">'
local fc_c  = '<font color="cyan">'
local fc_g  = '<font color=green">'
local fc_lb = '<font color="lightblue">'
local adminmail = false -- | Wenn true wird eine Mail an den admin Benutzer geschickt
local bdevices = fibaro.getDevicesID({interfaces ={"battery"},parentId = 1, enabled = true, isPlugin = false })
local quickapps = fibaro.getDevicesID({interfaces ={"quickApp"},parentId = 0, enabled = true  })
function checkDevices()
  local bdev, users, iosdev, nbdev, cam = 0,0,0,0,0;
  print(os.date('%c')..', Device inventory - Version: '.. version );
  print(fc_c.. 'Gathering device data...')
  local bdev = #bdevices
  local alldev = 0
  local dev = api.get('/devices')
  for _,p in pairs(dev) do
     if p.parentId == 1 then
        alldev = alldev +1
  nbdev = alldev - bdev
  -- Count other devices
  devices = fibaro.getDevicesID({visible = true, enabled = true, isPlugin = false })
  for id = 1, #devices do
      local dtype  = fibaro.getType(devices[id])
      if (dtype == 'iOS_device') then
          iosdev = iosdev+1;
        elseif (dtype == "com.fibaro.ipCamera") then
          cam = cam +1;
  end --for
  plugins  = fibaro.getDevicesID({ enabled = true, visible = true, isPlugin = true })
  --vdevices = fibaro.getDevicesID({ enabled = true, visible = true, type="virtual_device" })
  scenes   = api.get("/scenes")
  gvars    = api.get("/globalVariables")
  rooms    = api.get("/rooms")
  sections = api.get("/sections")
  users    = api.get("/users")
  separator = '------------------------------------------------'
  print(fc_g..'Here is your HC3 device list:')
  print(fc_lg .. separator)
  print(fc_lg.. alldev .. ' Total physical Z-Wave devices.')
  print(fc_o.. nbdev ..' Non batterie devices.')
  print(fc_o.. bdev ..' Batterie devices.')
  print(fc_o.. #users ..' HC3 Users.')
  print(fc_o.. iosdev ..' iOS/Android devices.')
  print(fc_o.. cam ..' ip Cameras.')
  print(fc_o.. #plugins .. ' Plugins in use.')
  print(fc_o.. #quickapps .. ' QuickApps in use.' )
  print(fc_o.. #scenes .. ' Scenes, including hidden scenes.')
  print(fc_o.. #gvars .. ' Global variables.')
  print(fc_o, 'There are '..#rooms ..' rooms  in '..#sections.. ' sections.')
  print(fc_lg.. separator)
  if adminmail then
     fibaro.alert("email", {2} , "Fibaro-Info - Geräte Inventur"..""
       ..alldev.." - Geräte sind insgesamt installiert\n"
       ..nbdev.." - Geräte mit Stromversorgung und\n"
       ..bdev.." - batteriebetriebene Geräte\n"
       ..#users.." - Benutzer\n"
       ..iosdev.. " - Android/iPhones Tablets\n"
       ..cam.. " - Kameras\n"
       ..#plugins.. " - Plugins\n"
       ..#quickapps.. " - Quickapps\n"
       ..#scenes.." - Szenen (auch versteckte)\n"
       ..#gvars.. " - globale Variablen\n"
       ..#rooms .." - Räume in "..#sections.." Bereichen \n"
       .."Übermittelt am "..os.date('%c')..'\n\n'  )
end  --function
checkDevices()
Hey jeep,
interessantes script. Hab´s ausprobiert, es läuft und gibt Infos wieder. Aber ich bekomme keine Mail.
Habe hier meine Mailadresse eingetragen:
if adminmail then
fibaro.alert(„email“, {2} , „Fibaro-Info - Geräte Inventur“..„“
bin neu, was mache ich falsch?
danke Chris
@dergnigler,
Du musst oben die Zeile „local adminmail = false“ auf „local adminmail = true“ abändern, mehr nicht.
Die Mail bringt Dir aber recht wenig, weil Fibaro zur Zeit ein Email Problem hat und alle Mails unformatiert ankommen.
hallo jeep,
besten Dank, vielleicht sollte ich einfach genauer lesen - eine Erklärung steht ja direkt in der Zeile…
hat bestens funktioniert, danke für deine Bemühungen!
schönen Tag noch
Chris
