Nachdem mich mein flooded network seit Monaten begleitet hat und ich nicht in der Lage war die Ursache zu finden, wandte ich mich am Montag an den Fibaro Support.
Auf Verlangen legte ich dem Support einen Zugang. Dienstag wurde den ganzen Tag auf meinem Home Center herumgewerkt. Neustarts, Backups, Restores …
Gegen 11:00 Uhr erhielt ich die erste Diagnose vom Support.
Your gateway is in great shape. The CPU level is low and only thing that slows it down is Netatmo plugin (uses up to 17% once every 10s), but it does not affect on your system stability.
Also your z-wave traffic does not cause the problem.
I’ve had created a backup before taking any actions.
Your issue could be related thou to devices pooling time interval. I’ve changed setting as you can see on attached screenshots. Those steps should help you.
I’ve also added “WakeUpdDeadNodes” script that will wake up all of your dead devices when run. You could automate this script to run every certain time. Please use this method if changes in z-wave configuration has not helped.
Um 17:30 kam die nächste Nachricht
Device of ID 100 has been reconfigured by me – unfortunately it has done hard reconfiguration and you should name it again and implement it to your scenes. Now the device is named as 1175.0
The issue that we’re facing with on your gateway is quite new – I’m speaking with our developers to make them look closer at your gateway via remote access, but I will require more patience in this case. We should know something before the weekend.
For now I would suggest to use LUA script that I’ve placed in your “unsigned” section to automate wake-up of devices.
Als ich gegen 18:30 das HC2 neu startete blieb das System bei “Starting Services” hängen.
Nach einer Stunde spielte ich das erste Backup ein. Resultat: 503 Server Unavailable
Bis Mitternacht habe ich drei Backups versucht. Alle endeten mit 503 Server Unavailable.
Natürlich habe ich dem Support geschrieben aber bisher noch nicht gehört. Auch scheint keiner auf dem HC2 zu arbeiten. Zumindest sehe ich keine Aktivitäten aus Polen so wie gestern auf meiner Firewall.
Es bleibt somit als letzte Hoffnung, dass der Support das System wieder hinbringt.
Wenn nicht, dann war es das endgültig für mich mit Haus Automatisation und Fibaro.
