perfekte Lichtsteuerung von heute auf morgen defekt?
Moin liebes Forum,
ich bekomme seit heute Morgen eine Fehlermeldung im Smart Light:
[DEBUG] 20:32:39: line 565: attempt to perform arithmetic on a nil value
hier der Code dazu (ich habe nichts verändert, lief wochenlang alles sauber). Wo ist das Problem, und wer hilft mir, es zu lösen? Danke im Voraus, Schnuckman
37 value
39 value
107 value
109 value
TimeOfDay
PresentState
--[[ Change - XXX value - above. One for motion sensor, one for Light sensor.
     TimeOfDay global variable and lux make sure that the scene
     will be triggered when you are already in the room and something changes.
     Set your settings below, lights and add extra functions
     Feel free to suggest changes or contact when having problems.
	 It is not allowed to sell or distribute this software and earlier versions without the approval of Control Living
     © 2014 - 2015 Smart lights by Control Living
     Version 1.6.7
-----------------------YOUR LIGHT SETTINGS--------------------------
motionSensorID    = {37,107};  -- change id for your motion sensor.
LuxSensorID       = {39,109};  -- change id for your light sensor.
--Enter the name of your Global variable. WITHOUT IT, THE SCENE DOES NOT WORK. Capital sensitive!
sleepState   = "SleepState"; --Sleep globalstate variable.
timeOfDay    = "TimeOfDay"; --Time of Day Global variable.
presentState = "PresentState"; --Present state Global variable.
--Enter the values of your global variables stated above. If not using, copy the name in front of the "YourValueName"
sleepStateMapping   = {Sleeping="Sleeping", Awake="Awake"};
timeOfDayMapping    = {Morning="Morning", Day="Day", Evening="Evening", Night="Night"};
presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"};
-- Set the lux value for which the lights have to be turned on.
-- If you don't want to use the MinLux then just set it to: 65535
minLuxMorning  = 65535;
minLuxDay      = 65535;
minLuxEvening  = 65535;
minLuxNight    = 65535;
--If the current lux value is above the maxlux, the lights will turn off after their set onTime.
maxLuxMorning = 300;
maxLuxDay = 300;
 Now the most important part:
   Here you can enter what light, for how long and at what value has to be turned on.
   Leave empty brackets for no lights.
   To set the light value without timer use 2 parameters: {id=LightID, setValue="VALUE"}
   To set the light value with timer    use 3 parameters: {id=LightID, setValue="VALUE", onTime=timeInSeconds }
   To set the light value for RGBW:  use the above, where setValue is: setValue={R="255",G="255",B="255",W="255"}
   --                                           RGBW set: {id=LightID, setValue={R="255",G="255",B="255",W="255"}, onTime=timeInSeconds }
lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping.
lightsMorning  = {{id=88, setValue="48", onTime=30}};
lightsDay      = {};
lightsEvening  = {{id=88, setValue="48", onTime=30}};
lightsNight    = {{id=88, setValue="28", onTime=30}};
--Manual Override, the time that lights will not be turned ON again after manually turning them off.
OverrideFor  = 90;
dimmDownTime = 5;
-------------------------EXTRA FEATURES-----------------------------
extraMorningFunc = function()
  -- Add your extra code here. If you want some checks or maybe run a virtual device button.
  --This code is always triggered if there is motion.
  -- movieLights =  {{180, "10"},{181, "10"} };
  --if (xbmc == "playing" ) then CallLightArray(movieLights);
  ExtraDebug("Extra morning function called");
extraDayFunc = function()
  ExtraDebug("Extra day function called");
extraEveningFunc = function()
  ExtraDebug("Extra evening function called");
extraNightFunc = function()
  ExtraDebug("Extra night function called");
extraLightTriggerChecks = function()
--add extra checks here. and return the total true or false value.
--if returning false the lights will not be triggered.
-- for instance:  return ( (pcTurnedOff == true ) and (xbmc ~= "Empty") );
  -- return true to enable lights to turn on
  return true;
extraOffChecks = function()
  --return true to keep lights on.
  return false;
----------------------ADVANCES SETTINGS-----------------------------
local showStandardDebugInfo = true; -- Debug shown in white
local showExtraDebugInfo    = false; -- Debug shown in orange
--               DO NOT CHANGE THE CODE BELOW                     --
--UPDATE FROM HERE
--private variables
startSource        = fibaro:getSourceTrigger();
keepLightsOn       = false;
timerRunning       = false;
previousLights     = nil;
version = "1.6.7";
SavedState = {
  homeStatus = "",
  sleepState = 0,
  timeOfDay  = "",
  lux        = 0,
  motion     = 0,
  startTime  = 0
CurrentState = {
  homeStatus  = "",
  sleepState  = "",
  timeOfDay   = "",
  lux         = 0,
  motionState = 0,
  currentLightArray = {}
RGBWDeviceType = { "com.fibaro.RGBW", "com.fibaro.colorController", "com.fibaro.FGRGBW441M"  }
BinaryDeviceType = { "com.fibaro.binarySwitch","com.fibaro.FGWP101", "turnOn"  }
DimmerDeviceType = { "com.fibaro.multilevelSwitch" }
OffModes = {None, ByScene, ManualOverride }
function Debug( color, message )
--Making sure that only one instance of the scene is running.
fibaro:sleep(50); --sleep to prevent all instances being killed.
  if (showExtraDebugInfo) then
    Debug( "grey", "Abort, Scene count = " .. fibaro:countScenes());
--------------------------EXECUTION----------------------------------
function SetCurrentStatus()
  ExtraDebug("Updating current variable statuses");
  CurrentState.homeStatus  = GetPresentState();
  CurrentState.timeOfDay   = GetTimeOfDay();
  CurrentState.sleepState  = GetSleepState();
  CurrentState.lux         = GetAverageLuxValue();
  CurrentState.motionState = GetCurrentMotionStatus();
function SaveCurrentStatus()
  ExtraDebug("Saving current variable statuses");
  SavedState.homeStatus = CurrentState.homeStatus;
  SavedState.timeOfDay  = CurrentState.timeOfDay;
  SavedState.sleepState = CurrentState.sleepState;
  SavedState.lux        = CurrentState.lux;
  SavedState.motion     = CurrentState.motionState;
function CheckStatusChanges()
  ExtraDebug("Status change check");
  if (CurrentState.homeStatus ~= SavedState.homeStatus ) or (CurrentState.timeOfDay ~= SavedState.timeOfDay ) then
    if (CurrentState.homeStatus ~= presentStateMapping.Home ) then
      TurnOffLights();
      SceneTriggered();
	  --reset time.
    end;
  SaveCurrentStatus();
    -- if we still have a motion then reset timer.
  if ( (CurrentState.motionState ~= 0 or extraOffChecks() ) and not IsMaxLuxExceeded() )  then
	ExtraDebug( "Resetting time" );
    SavedState.startTime = os.time();
    ExtraDebug("Timer is not reset.");
  --any other case, we are not resetting the timer.
function IsMaxLuxExceeded()
  if (CurrentState.timeOfDay == timeOfDayMapping.Morning and CurrentState.lux > maxLuxMorning ) then
    ExtraDebug( "Current lux value: " .. CurrentState.lux .. " higher then max Lux Morning: " .. maxLuxMorning .. ".");
	return true;
  elseif (CurrentState.timeOfDay == timeOfDayMapping.Day and CurrentState.lux > maxLuxDay ) then
    ExtraDebug( "Current lux value: " .. CurrentState.lux .. " higher then max Lux Day: " .. maxLuxDay .. ".");
	return true;
   return false;
function LightsOff( lightArray )
  local stillLightsOn = 0;
  local currentTime = os.time();
  for i = 1,#lightArray do
    if ( lightArray[i].onTime ~= nil) then
	  lightItem = lightArray[i];
	  lightItem.OffMode = CheckManualOverrideItem( lightItem );
	  --local
	  if ( lightItem.OffMode == "ManualOverride" ) then
	      ExtraDebug("Manual override for light: [" .. lightItem.id .. "]" .. lightItem.name .. " active, not turning on");
		  goto continue;
	  --On till:
      local timeL = SavedState.startTime + (lightItem.onTime);
	  local timeLeft =  timeL -  currentTime;
 	  if (timeLeft >= 0 ) then ExtraDebug("Time left for: [" .. lightItem.id .. "]" .. lightItem.name .. ": " .. timeLeft .. " seconds" );   end
	  if ( timeLeft < dimmDownTime ) then
        if ( lightItem.OffMode ~= "ManualOverride" ) then
			lightItem.OffMode = "ByScene";
	    if ( (timeLeft <= 0) and (lightItem.currentValue ~= 0) ) then
			fibaro:call(lightItem.id, "turnOff");
			StandardDebug("Switch off light: [" .. lightItem.id .. "]'" .. lightItem.name .."'");
            if ( item.lightType == "com.fibaro.multilevelSwitch" ) then
			  currentValueDiv = roundit(((lightItem.currentValue) / (dimmDownTime)), 0);
			  currentValueNew = (lightItem.currentValue - currentValueDiv);
			  if (currentValueNew <=0 ) then currentValueNew = 0; end
			  fibaro:call(lightItem.id, "setValue", tostring(currentValueNew));
			stillLightsOn = stillLightsOn + 1;
      elseif (CheckLightToBeTurnedOnAgain(lightItem)) then
        ExtraDebug("Turn light: " .. lightItem.id .. " back on");
        turnLightOn(lightItem);
		lightItem.OffMode = "";
	    lightItem.OffMode = "NoOverride";
	::continue::
  return stillLightsOn;
function KeepLightsOnTimer()
  ExtraDebug("--------------- Timer running ---------------");
  ExtraDebug("starting with while loop, to keep lights on");
  sleepTime = 1000;
  while ( keepLightsOn ) do
    ExtraDebug("--------------- next timer run ---------------");
    fibaro:sleep(sleepTime);
	start_time = os.clock();
    SetCurrentStatus();
    currentLightArray = GetTimeOfDayLightArray();
    UpdateLightValues(currentLightArray);
    CheckStatusChanges();
    stillLightsOn = LightsOff( currentLightArray );
    if (stillLightsOn == 0 ) then
	  keepLightsOn = RunManualOverrideMode( currentLightArray );
      end_time = 0; --if lights turned back on after override.
      end_time = os.clock()
	elapsed_time = (end_time - start_time) * 1000;
	sleepTime = 1000 - elapsed_time;
function CheckManualOverrideItem( currentItem )
  --ExtraDebug("Manual override check for: [" .. currentItem.id .. "]" .. currentItem.name);
  if (currentItem.currentValue == 0 and currentItem.OffMode ~= "ByScene" ) then
    ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " active" );
	return "ManualOverride";
  elseif (currentItem.currentValue ~= 0 and currentItem.OffMode == "ManualOverride" ) then
	ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " cancelled" );
	return "NoOverride";
  return currentItem.OffMode; --returning current mode;
function RunManualOverrideMode( currentLightArray )
  OverrideForAll = CheckIfAllInOverrideMode(currentLightArray);
  if ( OverrideForAll ) then
    ExtraDebug("-----------------Override Mode---------------");
    OverrideTimer = os.time();
    while ( OverrideForAll and (OverrideTimer + OverrideFor ) - os.time() > 0 ) do
      ExtraDebug("Still in override for: " .. (OverrideTimer + OverrideFor ) - os.time() .. " seconds" );
      fibaro:sleep(1000);
	  motion = GetCurrentMotionStatus();
	  if ( motion ~= 0 ) then
	else return false;
 -- if  ( (OverrideTimer + OverrideFor ) - os.time() <= 0 ) then
  --time has end. So not continue to run lights loop
 --   return false;
 -- end
  if (OverrideForAll) then
    return false; --run lights
  else return true;
function CheckIfAllInOverrideMode(currentLightArray)
  OverrideForAll = 0;
  for i = 1,#currentLightArray do
    if ( CheckManualOverrideItem(currentLightArray[i]) == "ManualOverride" ) then
      OverrideForAll = OverrideForAll +1;
      return false;
  if (  OverrideForAll ~= 0 and OverrideForAll == #currentLightArray ) then
    return true;
  return false;
function RunTimer()
if ( keepLightsOn and not timerRunning ) then
    ExtraDebug("Starting timer, not yet running");
    timerRunning = true;
    KeepLightsOnTimer();
	ExtraDebug("Timer already running, returning");
function TurnOffLights()
     local timeOfDayArray = GetTimeOfDayLightArray();
     SetLightValues(timeOfDayArray);
	 UpdateLightValues(timeOfDayArray);
     CallLightArray(timeOfDayArray, "off" );
	return;
----------------------Turn lights on functions------------------------
function CallLightArray( lightArray, turnOnOrOff )
  if (#lightArray == 0 ) then
    if (CurrentState.sleepState == sleepStateMapping.Sleeping) then
	  noLightsSetText = "lightsSleeping";
      noLightsSetText = CurrentState.timeOfDay;
    StandardDebug( "No lights set for " .. noLightsSetText );
    return;
  if not ( CheckIfTable(lightArray, "lights" .. CurrentState.timeOfDay ) ) then return end
    if not ( CheckIfTable(lightArray[i], "lights" .. CurrentState.timeOfDay ) ) then break end
    if (turnOnOrOff == "on" ) then
      if (lightItem.onTime ~= nil) then keepLightsOn = true; end
	  fibaro:call(lightItem.id, "turnOff"); --Always turn off, if HC2 light status is not actual.
      if ( lightItem.currentValue ~= 0) then
  StandardDebug( "Lights turned: " .. turnOnOrOff .. " for " .. CurrentState.timeOfDay );
function turnLightOn( lightItem )
  if (lightItem.lightType == "com.fibaro.multilevelSwitch" ) then
    fibaro:call(lightItem.id, "setValue", tostring(lightItem.setValue));
    StandardDebug( "Set: [" .. lightItem.id .. "]'" .. lightItem.name .. "' to Value: " .. lightItem.setValue );
  elseif ( lightItem.lightType == "com.fibaro.RGBW" )then
    StandardDebug( "Turn: [" .. lightItem.id .. "]'" .. lightItem.name .. "' On");
    if ( lightItem.setValue.brg~= nil ) then
      fibaro:call(lightItem.id, "setBrightness", tostring(lightItem.setValue.brg));
	  local clrvalues =lightItem.setValue;
      fibaro:call(lightItem.id, "setColor", clrvalues.R,  clrvalues.G,  clrvalues.B,  clrvalues.W)
  elseif (lightItem.lightType == "com.fibaro.binarySwitch") then
    fibaro:call(lightItem.id, "turnOn");
function CheckPreviousLights( NewLightArray )
  if ( previousLights ~= nil ) then
    for i = 1,#previousLights do
      local lightItem = previousLights[i];
      for i = 1,#NewLightArray do
        local lightItem1 = NewLightArray[i];
        inarray = false;
        if ( lightItem.id == lightItem1.id ) then
          inarray= true;
          break
      if not ( inarray ) then fibaro:call(lightItem.id, "turnOff"); end
  previousLights = NewLightArray;
function LightperDayPart( minLux, lightArray )
  local newLuxValue = CurrentState.lux;
  if ( extraLightTriggerChecks() ) then
    if ( newLuxValue  >  minLux )  then
      StandardDebug( "Sensor lux: " .. newLuxValue .. " higher then minValue: " .. minLux .. " : no action");
      StandardDebug("Sensor lux: " .. newLuxValue .. " is lower then minValue: " .. minLux);
	  SetLightValues(lightArray);
	  CallLightArray( lightArray, "on" );
	  CheckPreviousLights( lightArray );
    ExtraDebug("ExtraLightTriggerChecks failed, so no lights");
function SceneTriggered()
  if ( CurrentState.homeStatus ~= presentStateMapping.Home ) then
	ExtraDebug("Presentstate = not at home, so no lights");
  elseif  ( CurrentState.sleepState == sleepStateMapping.Sleeping ) then
    LightperDayPart( 65535, lightsSleeping );
  elseif ( CurrentState.timeOfDay == timeOfDayMapping.Morning ) then
    extraMorningFunc();
    LightperDayPart( minLuxMorning, lightsMorning );
  elseif ( CurrentState.timeOfDay == timeOfDayMapping.Day ) then
    extraDayFunc();
	LightperDayPart( minLuxDay, lightsDay );
  elseif ( CurrentState.timeOfDay == timeOfDayMapping.Evening ) then
    extraEveningFunc();
    LightperDayPart( minLuxEvening, lightsEvening );
  elseif ( CurrentState.timeOfDay == timeOfDayMapping.Night  ) then
    extraNightFunc();
    LightperDayPart( minLuxNight, lightsNight );
	ErrorDebug( "No lights: " .. CurrentState.timeOfDay );
  if (keepLightsOn == true) then
    RunTimer();
function SceneTriggeredByLights( st )
  if (st == "off") then
    ExtraDebug( "light turned off, sleep 4 sec" );
    fibaro:sleep(4000);
  elseif (st == "on") then
    ExtraDebug( "light turned on, activating timer" );
	fibaro:sleep(4000);
	--TODO: add light to current array.
	--keepLightsOn = true;
	--RunTimer();
------------------------STATUS functions------------------------------
function GetTimeOfDay()
  return LookupGlobal( timeOfDay, "TimeOfDay", "Day");
function GetSleepState()
  return LookupGlobal( sleepState, "sleepState", "Awake");
function GetPresentState()
  return LookupGlobal( presentState, "presentState", "Home");
function LookupGlobal( name, stateName, default )
  local ps = fibaro:getGlobalValue( name );
  if ( (ps ~= "") and (ps ~= nil ) ) then
    ExtraDebug("returned " .. stateName .. ": " .. ps );
    return ps;
    ErrorDebug( stateName .. " variable not found");
    return default;
function lightsStatus( id )
  --check if lights are already on.
  allLights = {lightsSleeping, lightsMorning, lightsDay, lightsEvening, lightsNight };
  for i = 1,#allLights do
    for iL = 1, #allLights[i] do
	  local lightItem =  allLights[i][iL];
      if ( lightItem.id == tonumber(id) ) then
        if   ( lightItem.currentValue == 0 ) then
          return "off";
          return "on";
  ErrorDebug("Light status unknown");
  return "Unknown";
function GetTimeOfDayLightArray()
    return lightsSleeping;
    return lightsMorning;
	return lightsDay;
	return lightsEvening;
	return lightsNight;
function GetCurrentMotionStatus()
  local sensorbreached = 0;
  if (CheckIfTable(motionSensorID, "motionSensorID") ) then
    for i = 1,#motionSensorID do
      if ( tonumber(fibaro:getValue(motionSensorID[i], "value")) > 0 ) then
        sensorbreached = 1;
    --if not a table, just return the value of the containing ID
	sensorbreached = tonumber(fibaro:getValue(motionSensorID, "value"))
  return sensorbreached;
function GetAverageLuxValue()
  local luxAverage = 0;
  if (CheckIfTable(LuxSensorID, "LuxSensorID") ) then
    if (#LuxSensorID == 1) then
      return tonumber(fibaro:getValue(LuxSensorID[1], "value"));
    for i = 1,#LuxSensorID do
      luxAverage = luxAverage + tonumber(fibaro:getValue(LuxSensorID[i], "value"));
      luxAverage = roundit( (luxAverage / #LuxSensorID), 0 );
    luxAverage = tonumber(fibaro:getValue(LuxSensorID, "value"));
  return luxAverage;
function UpdateLightValues( currentArray )
  for i = 1,#currentArray do
    item = currentArray[i];
	newValue = fibaro:getValue(item.id, "value");
	item.currentValue = tonumber(newValue) ~= nil and tonumber(newValue) or ( newValue == "true" and 1 or 0 );
    if ( item.lightType == "com.fibaro.RGBW" )then
         color = fibaro:getValue(item.id, "color");
         c = {R="0", G="0", B="0", W="0", brg="0" }
         c.R, c.G, c.B, c.W = color:match("([^,]+),([^,]+),([^,]+),([^,]+)");
         c.brg = fibaro:getValue(item.id, "brightness");
         item.currentValue = c;
function SetLightValues(currentArray)
    item.name = tostring(fibaro:getName(item.id));
	item.OffMode = "NoOverride";
	if (item.name == nil) then item.name = "Unknown"; end
    item.lightType = GetDeviceType( item.id );
function GetDeviceType(itemId)
  deviceType = fibaro:getType(item.id);
  if ( idIsInList(deviceType, RGBWDeviceType) ) then
      deviceType ="com.fibaro.RGBW";
  elseif ( idIsInList(deviceType, BinaryDeviceType) ) then
       deviceType = "com.fibaro.binarySwitch";
  elseif ( idIsInList(deviceType, DimmerDeviceType ) ) then
       deviceType = "com.fibaro.multilevelSwitch";
 --elseif( ) then
 --deviceType = "Philips.Hue";
    return deviceType;
--------------------Helper functions--------------------------------
function CheckLightToBeTurnedOnAgain(lightItem)
 if not (lightItem.OffMode=="ByScene") then return; end
   if (lightItem.currentValue) < tonumber(lightItem.setValue) then return true; end
 elseif( lightItem.lightType == "com.fibaro.RGBW" )then
   c = lightItem.currentValue;
   if (c.R == "0" and c.G == "0" and c.B == "0" and c.W == "0" ) then
     return true;
   if (lightItem.setValue == "turnOn" and lightItem.currentValue == 0 ) then return true; end
  return false;
function CheckIfTable( array, arrayname )
  local tableCheck = tostring( type( array ) );
  if ( tableCheck ~= "table" ) then
    ErrorDebug("Missing brackets for variable: '" .. arrayname .. "', please place extra brackts: { } around: " .. array .. ".");
	return false;
  return true;
function roundit(num, idp)
  local mult = 10^(idp or 0)
  return math.floor(num * mult + 0.5) / mult
function idIsInList( startSourceId, sensorList )
  for i = 1,#sensorList do
    if ( startSourceId == sensorList[i] ) then
      return true;
  return false;
--------------------Debugging Functions-----------------------------
function StandardDebug( debugMessage )
  if ( showStandardDebugInfo ) then
    Debug( "white", debugMessage);
function ExtraDebug( debugMessage )
  if ( showExtraDebugInfo ) then
    Debug( "orange", debugMessage);
function ErrorDebug( debugMessage )
    Debug( "red", "Error: " .. debugMessage);
    Debug( "red", "");
function TestDebug(debugMessage )
   Debug( "blue", "Testing: " .. debugMessage );
----------------------START OF THE SCENE----------------------------
SetCurrentStatus();
StandardDebug("Home status: " .. CurrentState.homeStatus );
StandardDebug("Motion status: " .. ( CurrentState.motionState == 0 and "No movement" or "movement"));
if (startSource["type"] == "property") then
  startSourceID = tonumber(startSource['deviceID']);
  triggerDebug  = "Triggered by: " .. startSourceID;
  if ( idIsInList( startSourceID, motionSensorID ) ) then
    StandardDebug( triggerDebug .. " Motion sensor" );
    if ( CurrentState.motionState > 0 ) then
      SceneTriggered();
  elseif ( idIsInList( startSourceID, LuxSensorID ) ) then
    StandardDebug( triggerDebug .. " Lux sensor" );
    ExtraDebug( "Lux value changed to: " .. CurrentState.lux );
      SceneTriggered();
    StandardDebug( triggerDebug .. " Light switch" );
    st = lightsStatus( startSourceID );
    if (st == "Unknown") then
      ErrorDebug( "Unknown light trigger" );
	  SceneTriggeredByLights( st );
    -- Maybe we can change the light preset to make it more intelligent.
    -- Maybe we can change the Lux preset to make it more intelligent.
elseif ( startSource["type"] == "global" ) then
  StandardDebug( "Triggered by: " .. "global variable" );
  -- If home status away, we trigger so the current array will be turned off. If motion, turn them on.
  if (CurrentState.homeStatus ~= presentStateMapping.Home) then
    TurnOffLights();
  elseif (CurrentState.motionState > 0 ) then
    SceneTriggered();
  StandardDebug( "Triggered by: " .. startSource["type"] .. " , Not checking the motion state." );
  --Just run the Light Code, not checking for motion. Probably triggered manually.
  if ( startSource["type"] == "other" ) then
    SceneTriggered();
Debug( "green", "© Smart Lights V" .. version .. " | by Control Living, Finished" );
Debug( "green", "-------------------------------------------------------" );
--fibaro:abort(); --otherwise scene will stay alive to long.
--UPDATE TILL HERE
Hast du mal geprüft ob die ID’s noch die richtigen sind?
Ich hatte neulich auch das Problem das sie sich geändert hatten, obwohl ich nichts daran geändert habe.
Am besten eine Debug Zeile vor der Zeile mit Fehler einfügen und i ins Log zu schreiben.
Dann siehst Du welcher Sensor (Wert vor Fehler) das Problem verursacht.
Möglicherweise hast du einen „Death Node“
Ui, tatsächlich hat das HC2 den Fibaro Motion Sensor einfach rausgekegelt. Hab ihn jetzt neu eingebunden und die IDs angepasst, jetzt läuft das Skript zumindest wieder durch. Nur geht das Licht (ID 88 im Skript oben) nicht an (bei keinem der beiden triggernden MS). Da werde ich nächste Woche nochmal forschen, warum nicht, schaffe ich nicht übers WE.
VG
Schnuckman
