habe die perfekte Lichtsteuerung aus dem Forum hier in mehreren Räumen laufen.
bei allen schaltet sich das Licht nach Ablauf der Ontime direkt aus, außer bei dem folgenden Script.
Hier dimmen die Lampen in ca 25% Schritten bis auf 0% runter. ich weiss nicht wieso und ich möchte das eigentlich auch nicht.
ich finde allerdings im script keinen unterschied zu den anderen bei mir laufenden…
evtl seht ihr wo dran das liegt? an den einstellungen im Dimmer 2 liegt es auch nicht…
5 value
175 value
7 value
177 value
TimeOfDay
PresentState
--[[ Change - XXX value - above. One for motion sensor, one for Light sensor.
TimeOfDay global variable and lux make sure that the scene
will be triggered when you are already in the room and something changes.
Set your settings below, lights and add extra functions
Feel free to suggest changes or contact when having problems.
It is not allowed to sell or distribute this software and earlier versions without the approval of Control Living
© 2014 - 2015 Smart lights by Control Living
Version 1.6.7
-----------------------YOUR LIGHT SETTINGS--------------------------
motionSensorID = {5, 175}; -- change id for your motion sensor.
LuxSensorID = {7, 177}; -- change id for your light sensor.
--Enter the name of your Global variable. WITHOUT IT, THE SCENE DOES NOT WORK. Capital sensitive!
sleepState = "SleepState"; --Sleep globalstate variable.
timeOfDay = "TimeOfDay"; --Time of Day Global variable.
presentState = "PresentState"; --Present state Global variable.
--Enter the values of your global variables stated above. If not using, copy the name in front of the "YourValueName"
sleepStateMapping = {Sleeping="Sleeping", Awake="Awake"};
timeOfDayMapping = {Morning="Morning", Day="Day", Evening="Evening", Night="Night"};
presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"};
-- Set the lux value for which the lights have to be turned on.
-- If you don't want to use the MinLux then just set it to: 65535
minLuxMorning = 65535;
minLuxDay = 65535;
minLuxEvening = 65535;
minLuxNight = 65535;
--If the current lux value is above the maxlux, the lights will turn off after their set onTime.
maxLuxMorning = 300;
maxLuxDay = 300;
Now the most important part:
Here you can enter what light, for how long and at what value has to be turned on.
Leave empty brackets for no lights.
To set the light value without timer use 2 parameters: {id=LightID, setValue="VALUE"}
To set the light value with timer use 3 parameters: {id=LightID, setValue="VALUE", onTime=timeInSeconds }
To set the light value for RGBW: use the above, where setValue is: setValue={R="255",G="255",B="255",W="255"}
-- RGBW set: {id=LightID, setValue={R="255",G="255",B="255",W="255"}, onTime=timeInSeconds }
lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping.
lightsMorning = {{id=93, setValue="30", onTime=180}};
lightsDay = {{id=93, setValue="80", onTime=180}};
lightsEvening = {{id=93, setValue="30", onTime=180}};
lightsNight = {{id=93, setValue="10", onTime=180}};
--Manual Override, the time that lights will not be turned ON again after manually turning them off.
OverrideFor = 90;
dimmDownTime = 10;
-------------------------EXTRA FEATURES-----------------------------
extraMorningFunc = function()
-- Add your extra code here. If you want some checks or maybe run a virtual device button.
--This code is always triggered if there is motion.
-- movieLights = {{180, "10"},{181, "10"} };
--if (xbmc == "playing" ) then CallLightArray(movieLights);
ExtraDebug("Extra morning function called");
extraDayFunc = function()
ExtraDebug("Extra day function called");
extraEveningFunc = function()
ExtraDebug("Extra evening function called");
extraNightFunc = function()
ExtraDebug("Extra night function called");
extraLightTriggerChecks = function()
--add extra checks here. and return the total true or false value.
--if returning false the lights will not be triggered.
-- for instance: return ( (pcTurnedOff == true ) and (xbmc ~= "Empty") );
-- return true to enable lights to turn on
return true;
extraOffChecks = function()
--return true to keep lights on.
return false;
----------------------ADVANCES SETTINGS-----------------------------
local showStandardDebugInfo = true; -- Debug shown in white
local showExtraDebugInfo = false; -- Debug shown in orange
-- DO NOT CHANGE THE CODE BELOW --
--UPDATE FROM HERE
--private variables
startSource = fibaro:getSourceTrigger();
keepLightsOn = false;
timerRunning = false;
previousLights = nil;
version = "1.6.7";
SavedState = {
homeStatus = "",
sleepState = 0,
timeOfDay = "",
lux = 0,
motion = 0,
startTime = 0
CurrentState = {
homeStatus = "",
sleepState = "",
timeOfDay = "",
lux = 0,
motionState = 0,
currentLightArray = {}
RGBWDeviceType = { "com.fibaro.RGBW", "com.fibaro.colorController", "com.fibaro.FGRGBW441M" }
BinaryDeviceType = { "com.fibaro.binarySwitch","com.fibaro.FGWP101", "turnOn" }
DimmerDeviceType = { "com.fibaro.multilevelSwitch" }
OffModes = {None, ByScene, ManualOverride }
function Debug( color, message )
--Making sure that only one instance of the scene is running.
fibaro:sleep(50); --sleep to prevent all instances being killed.
if (showExtraDebugInfo) then
Debug( "grey", "Abort, Scene count = " .. fibaro:countScenes());
--------------------------EXECUTION----------------------------------
function SetCurrentStatus()
ExtraDebug("Updating current variable statuses");
CurrentState.homeStatus = GetPresentState();
CurrentState.timeOfDay = GetTimeOfDay();
CurrentState.sleepState = GetSleepState();
CurrentState.lux = GetAverageLuxValue();
CurrentState.motionState = GetCurrentMotionStatus();
function SaveCurrentStatus()
ExtraDebug("Saving current variable statuses");
SavedState.homeStatus = CurrentState.homeStatus;
SavedState.timeOfDay = CurrentState.timeOfDay;
SavedState.sleepState = CurrentState.sleepState;
SavedState.lux = CurrentState.lux;
SavedState.motion = CurrentState.motionState;
function CheckStatusChanges()
ExtraDebug("Status change check");
if (CurrentState.homeStatus ~= SavedState.homeStatus ) or (CurrentState.timeOfDay ~= SavedState.timeOfDay ) then
if (CurrentState.homeStatus ~= presentStateMapping.Home ) then
TurnOffLights();
SceneTriggered();
--reset time.
end;
SaveCurrentStatus();
-- if we still have a motion then reset timer.
if ( (CurrentState.motionState ~= 0 or extraOffChecks() ) and not IsMaxLuxExceeded() ) then
ExtraDebug( "Resetting time" );
SavedState.startTime = os.time();
ExtraDebug("Timer is not reset.");
--any other case, we are not resetting the timer.
function IsMaxLuxExceeded()
if (CurrentState.timeOfDay == timeOfDayMapping.Morning and CurrentState.lux > maxLuxMorning ) then
ExtraDebug( "Current lux value: " .. CurrentState.lux .. " higher then max Lux Morning: " .. maxLuxMorning .. ".");
return true;
elseif (CurrentState.timeOfDay == timeOfDayMapping.Day and CurrentState.lux > maxLuxDay ) then
ExtraDebug( "Current lux value: " .. CurrentState.lux .. " higher then max Lux Day: " .. maxLuxDay .. ".");
return true;
return false;
function LightsOff( lightArray )
local stillLightsOn = 0;
local currentTime = os.time();
for i = 1,#lightArray do
if ( lightArray[i].onTime ~= nil) then
lightItem = lightArray[i];
lightItem.OffMode = CheckManualOverrideItem( lightItem );
--local
if ( lightItem.OffMode == "ManualOverride" ) then
ExtraDebug("Manual override for light: [" .. lightItem.id .. "]" .. lightItem.name .. " active, not turning on");
goto continue;
--On till:
local timeL = SavedState.startTime + (lightItem.onTime);
local timeLeft = timeL - currentTime;
if (timeLeft >= 0 ) then ExtraDebug("Time left for: [" .. lightItem.id .. "]" .. lightItem.name .. ": " .. timeLeft .. " seconds" ); end
if ( timeLeft < dimmDownTime ) then
if ( lightItem.OffMode ~= "ManualOverride" ) then
lightItem.OffMode = "ByScene";
if ( (timeLeft <= 0) and (lightItem.currentValue ~= 0) ) then
fibaro:call(lightItem.id, "turnOff");
StandardDebug("Switch off light: [" .. lightItem.id .. "]'" .. lightItem.name .."'");
if ( item.lightType == "com.fibaro.multilevelSwitch" ) then
currentValueDiv = roundit(((lightItem.currentValue) / (dimmDownTime)), 0);
currentValueNew = (lightItem.currentValue - currentValueDiv);
if (currentValueNew <=0 ) then currentValueNew = 0; end
fibaro:call(lightItem.id, "setValue", tostring(currentValueNew));
stillLightsOn = stillLightsOn + 1;
elseif (CheckLightToBeTurnedOnAgain(lightItem)) then
ExtraDebug("Turn light: " .. lightItem.id .. " back on");
turnLightOn(lightItem);
lightItem.OffMode = "";
lightItem.OffMode = "NoOverride";
::continue::
return stillLightsOn;
function KeepLightsOnTimer()
ExtraDebug("--------------- Timer running ---------------");
ExtraDebug("starting with while loop, to keep lights on");
sleepTime = 1000;
while ( keepLightsOn ) do
ExtraDebug("--------------- next timer run ---------------");
fibaro:sleep(sleepTime);
start_time = os.clock();
SetCurrentStatus();
currentLightArray = GetTimeOfDayLightArray();
UpdateLightValues(currentLightArray);
CheckStatusChanges();
stillLightsOn = LightsOff( currentLightArray );
if (stillLightsOn == 0 ) then
keepLightsOn = RunManualOverrideMode( currentLightArray );
end_time = 0; --if lights turned back on after override.
end_time = os.clock()
elapsed_time = (end_time - start_time) * 1000;
sleepTime = 1000 - elapsed_time;
function CheckManualOverrideItem( currentItem )
--ExtraDebug("Manual override check for: [" .. currentItem.id .. "]" .. currentItem.name);
if (currentItem.currentValue == 0 and currentItem.OffMode ~= "ByScene" ) then
ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " active" );
return "ManualOverride";
elseif (currentItem.currentValue ~= 0 and currentItem.OffMode == "ManualOverride" ) then
ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " cancelled" );
return "NoOverride";
return currentItem.OffMode; --returning current mode;
function RunManualOverrideMode( currentLightArray )
OverrideForAll = CheckIfAllInOverrideMode(currentLightArray);
if ( OverrideForAll ) then
ExtraDebug("-----------------Override Mode---------------");
OverrideTimer = os.time();
while ( OverrideForAll and (OverrideTimer + OverrideFor ) - os.time() > 0 ) do
ExtraDebug("Still in override for: " .. (OverrideTimer + OverrideFor ) - os.time() .. " seconds" );
fibaro:sleep(1000);
motion = GetCurrentMotionStatus();
if ( motion ~= 0 ) then
else return false;
-- if ( (OverrideTimer + OverrideFor ) - os.time() <= 0 ) then
--time has end. So not continue to run lights loop
-- return false;
-- end
if (OverrideForAll) then
return false; --run lights
else return true;
function CheckIfAllInOverrideMode(currentLightArray)
OverrideForAll = 0;
for i = 1,#currentLightArray do
if ( CheckManualOverrideItem(currentLightArray[i]) == "ManualOverride" ) then
OverrideForAll = OverrideForAll +1;
return false;
if ( OverrideForAll ~= 0 and OverrideForAll == #currentLightArray ) then
return true;
return false;
function RunTimer()
if ( keepLightsOn and not timerRunning ) then
ExtraDebug("Starting timer, not yet running");
timerRunning = true;
KeepLightsOnTimer();
ExtraDebug("Timer already running, returning");
function TurnOffLights()
local timeOfDayArray = GetTimeOfDayLightArray();
SetLightValues(timeOfDayArray);
UpdateLightValues(timeOfDayArray);
CallLightArray(timeOfDayArray, "off" );
return;
----------------------Turn lights on functions------------------------
function CallLightArray( lightArray, turnOnOrOff )
if (#lightArray == 0 ) then
if (CurrentState.sleepState == sleepStateMapping.Sleeping) then
noLightsSetText = "lightsSleeping";
noLightsSetText = CurrentState.timeOfDay;
StandardDebug( "No lights set for " .. noLightsSetText );
return;
if not ( CheckIfTable(lightArray, "lights" .. CurrentState.timeOfDay ) ) then return end
if not ( CheckIfTable(lightArray[i], "lights" .. CurrentState.timeOfDay ) ) then break end
if (turnOnOrOff == "on" ) then
if (lightItem.onTime ~= nil) then keepLightsOn = true; end
fibaro:call(lightItem.id, "turnOff"); --Always turn off, if HC2 light status is not actual.
if ( lightItem.currentValue ~= 0) then
StandardDebug( "Lights turned: " .. turnOnOrOff .. " for " .. CurrentState.timeOfDay );
function turnLightOn( lightItem )
if (lightItem.lightType == "com.fibaro.multilevelSwitch" ) then
fibaro:call(lightItem.id, "setValue", tostring(lightItem.setValue));
StandardDebug( "Set: [" .. lightItem.id .. "]'" .. lightItem.name .. "' to Value: " .. lightItem.setValue );
elseif ( lightItem.lightType == "com.fibaro.RGBW" )then
StandardDebug( "Turn: [" .. lightItem.id .. "]'" .. lightItem.name .. "' On");
if ( lightItem.setValue.brg~= nil ) then
fibaro:call(lightItem.id, "setBrightness", tostring(lightItem.setValue.brg));
local clrvalues =lightItem.setValue;
fibaro:call(lightItem.id, "setColor", clrvalues.R, clrvalues.G, clrvalues.B, clrvalues.W)
elseif (lightItem.lightType == "com.fibaro.binarySwitch") then
fibaro:call(lightItem.id, "turnOn");
function CheckPreviousLights( NewLightArray )
if ( previousLights ~= nil ) then
for i = 1,#previousLights do
local lightItem = previousLights[i];
for i = 1,#NewLightArray do
local lightItem1 = NewLightArray[i];
inarray = false;
if ( lightItem.id == lightItem1.id ) then
inarray= true;
break
if not ( inarray ) then fibaro:call(lightItem.id, "turnOff"); end
previousLights = NewLightArray;
function LightperDayPart( minLux, lightArray )
local newLuxValue = CurrentState.lux;
if ( extraLightTriggerChecks() ) then
if ( newLuxValue > minLux ) then
StandardDebug( "Sensor lux: " .. newLuxValue .. " higher then minValue: " .. minLux .. " : no action");
StandardDebug("Sensor lux: " .. newLuxValue .. " is lower then minValue: " .. minLux);
SetLightValues(lightArray);
CallLightArray( lightArray, "on" );
CheckPreviousLights( lightArray );
ExtraDebug("ExtraLightTriggerChecks failed, so no lights");
function SceneTriggered()
if ( CurrentState.homeStatus ~= presentStateMapping.Home ) then
ExtraDebug("Presentstate = not at home, so no lights");
elseif ( CurrentState.sleepState == sleepStateMapping.Sleeping ) then
LightperDayPart( 65535, lightsSleeping );
elseif ( CurrentState.timeOfDay == timeOfDayMapping.Morning ) then
extraMorningFunc();
LightperDayPart( minLuxMorning, lightsMorning );
elseif ( CurrentState.timeOfDay == timeOfDayMapping.Day ) then
extraDayFunc();
LightperDayPart( minLuxDay, lightsDay );
elseif ( CurrentState.timeOfDay == timeOfDayMapping.Evening ) then
extraEveningFunc();
LightperDayPart( minLuxEvening, lightsEvening );
elseif ( CurrentState.timeOfDay == timeOfDayMapping.Night ) then
extraNightFunc();
LightperDayPart( minLuxNight, lightsNight );
ErrorDebug( "No lights: " .. CurrentState.timeOfDay );
if (keepLightsOn == true) then
RunTimer();
function SceneTriggeredByLights( st )
if (st == "off") then
ExtraDebug( "light turned off, sleep 4 sec" );
fibaro:sleep(4000);
elseif (st == "on") then
ExtraDebug( "light turned on, activating timer" );
fibaro:sleep(4000);
--TODO: add light to current array.
--keepLightsOn = true;
--RunTimer();
------------------------STATUS functions------------------------------
function GetTimeOfDay()
return LookupGlobal( timeOfDay, "TimeOfDay", "Day");
function GetSleepState()
return LookupGlobal( sleepState, "sleepState", "Awake");
function GetPresentState()
return LookupGlobal( presentState, "presentState", "Home");
function LookupGlobal( name, stateName, default )
local ps = fibaro:getGlobalValue( name );
if ( (ps ~= "") and (ps ~= nil ) ) then
ExtraDebug("returned " .. stateName .. ": " .. ps );
return ps;
ErrorDebug( stateName .. " variable not found");
return default;
function lightsStatus( id )
--check if lights are already on.
allLights = {lightsSleeping, lightsMorning, lightsDay, lightsEvening, lightsNight };
for i = 1,#allLights do
for iL = 1, #allLights[i] do
local lightItem = allLights[i][iL];
if ( lightItem.id == tonumber(id) ) then
if ( lightItem.currentValue == 0 ) then
return "off";
return "on";
ErrorDebug("Light status unknown");
return "Unknown";
function GetTimeOfDayLightArray()
return lightsSleeping;
return lightsMorning;
return lightsDay;
return lightsEvening;
return lightsNight;
function GetCurrentMotionStatus()
local sensorbreached = 0;
if (CheckIfTable(motionSensorID, "motionSensorID") ) then
for i = 1,#motionSensorID do
if ( tonumber(fibaro:getValue(motionSensorID[i], "value")) > 0 ) then
sensorbreached = 1;
--if not a table, just return the value of the containing ID
sensorbreached = tonumber(fibaro:getValue(motionSensorID, "value"))
return sensorbreached;
function GetAverageLuxValue()
local luxAverage = 0;
if (CheckIfTable(LuxSensorID, "LuxSensorID") ) then
if (#LuxSensorID == 1) then
return tonumber(fibaro:getValue(LuxSensorID[1], "value"));
for i = 1,#LuxSensorID do
luxAverage = luxAverage + tonumber(fibaro:getValue(LuxSensorID[i], "value"));
luxAverage = roundit( (luxAverage / #LuxSensorID), 0 );
luxAverage = tonumber(fibaro:getValue(LuxSensorID, "value"));
return luxAverage;
function UpdateLightValues( currentArray )
for i = 1,#currentArray do
item = currentArray[i];
newValue = fibaro:getValue(item.id, "value");
item.currentValue = tonumber(newValue) ~= nil and tonumber(newValue) or ( newValue == "true" and 1 or 0 );
if ( item.lightType == "com.fibaro.RGBW" )then
color = fibaro:getValue(item.id, "color");
c = {R="0", G="0", B="0", W="0", brg="0" }
c.R, c.G, c.B, c.W = color:match("([^,]+),([^,]+),([^,]+),([^,]+)");
c.brg = fibaro:getValue(item.id, "brightness");
item.currentValue = c;
function SetLightValues(currentArray)
item.name = tostring(fibaro:getName(item.id));
item.OffMode = "NoOverride";
if (item.name == nil) then item.name = "Unknown"; end
item.lightType = GetDeviceType( item.id );
function GetDeviceType(itemId)
deviceType = fibaro:getType(item.id);
if ( idIsInList(deviceType, RGBWDeviceType) ) then
deviceType ="com.fibaro.RGBW";
elseif ( idIsInList(deviceType, BinaryDeviceType) ) then
deviceType = "com.fibaro.binarySwitch";
elseif ( idIsInList(deviceType, DimmerDeviceType ) ) then
deviceType = "com.fibaro.multilevelSwitch";
--elseif( ) then
--deviceType = "Philips.Hue";
return deviceType;
--------------------Helper functions--------------------------------
function CheckLightToBeTurnedOnAgain(lightItem)
if not (lightItem.OffMode=="ByScene") then return; end
if (lightItem.currentValue) < tonumber(lightItem.setValue) then return true; end
elseif( lightItem.lightType == "com.fibaro.RGBW" )then
c = lightItem.currentValue;
if (c.R == "0" and c.G == "0" and c.B == "0" and c.W == "0" ) then
return true;
if (lightItem.setValue == "turnOn" and lightItem.currentValue == 0 ) then return true; end
return false;
function CheckIfTable( array, arrayname )
local tableCheck = tostring( type( array ) );
if ( tableCheck ~= "table" ) then
ErrorDebug("Missing brackets for variable: '" .. arrayname .. "', please place extra brackts: { } around: " .. array .. ".");
return false;
return true;
function roundit(num, idp)
local mult = 10^(idp or 0)
return math.floor(num * mult + 0.5) / mult
function idIsInList( startSourceId, sensorList )
for i = 1,#sensorList do
if ( startSourceId == sensorList[i] ) then
return true;
return false;
--------------------Debugging Functions-----------------------------
function StandardDebug( debugMessage )
if ( showStandardDebugInfo ) then
Debug( "white", debugMessage);
function ExtraDebug( debugMessage )
if ( showExtraDebugInfo ) then
Debug( "orange", debugMessage);
function ErrorDebug( debugMessage )
Debug( "red", "Error: " .. debugMessage);
Debug( "red", "");
function TestDebug(debugMessage )
Debug( "blue", "Testing: " .. debugMessage );
----------------------START OF THE SCENE----------------------------
SetCurrentStatus();
StandardDebug("Home status: " .. CurrentState.homeStatus );
StandardDebug("Motion status: " .. ( CurrentState.motionState == 0 and "No movement" or "movement"));
if (startSource["type"] == "property") then
startSourceID = tonumber(startSource['deviceID']);
triggerDebug = "Triggered by: " .. startSourceID;
if ( idIsInList( startSourceID, motionSensorID ) ) then
StandardDebug( triggerDebug .. " Motion sensor" );
if ( CurrentState.motionState > 0 ) then
SceneTriggered();
elseif ( idIsInList( startSourceID, LuxSensorID ) ) then
StandardDebug( triggerDebug .. " Lux sensor" );
ExtraDebug( "Lux value changed to: " .. CurrentState.lux );
SceneTriggered();
StandardDebug( triggerDebug .. " Light switch" );
st = lightsStatus( startSourceID );
if (st == "Unknown") then
ErrorDebug( "Unknown light trigger" );
SceneTriggeredByLights( st );
-- Maybe we can change the light preset to make it more intelligent.
-- Maybe we can change the Lux preset to make it more intelligent.
elseif ( startSource["type"] == "global" ) then
StandardDebug( "Triggered by: " .. "global variable" );
-- If home status away, we trigger so the current array will be turned off. If motion, turn them on.
if (CurrentState.homeStatus ~= presentStateMapping.Home) then
TurnOffLights();
elseif (CurrentState.motionState > 0 ) then
SceneTriggered();
StandardDebug( "Triggered by: " .. startSource["type"] .. " , Not checking the motion state." );
--Just run the Light Code, not checking for motion. Probably triggered manually.
if ( startSource["type"] == "other" ) then
SceneTriggered();
Debug( "green", "© Smart Lights V" .. version .. " | by Control Living, Finished" );
Debug( "green", "-------------------------------------------------------" );
--fibaro:abort(); --otherwise scene will stay alive to long.
--UPDATE TILL HERE
danke
Mit freundlichen Grüßen
bademeister
