Mir fehlt seit neuestem ein Gerät in der Liste und das äußert sich sehr seltsam
[DEBUG] 11:35:58: 41–
[DEBUG] 11:35:58: Neighbours of device 747) HausTür : [1,305,323,325,328,331,372,381,513,425,430,473,497,504,614,619,710,717,739]
[DEBUG] 11:35:58: Last working route used by device 747 : [1,323]
[DEBUG] 11:35:58: 42–
[DEBUG] 11:35:59: Neighbours of device 751) Bad Dach : [372,614,619,717,739]
[DEBUG] 11:35:59: Last working route used by device 751 : [1]
[DEBUG] 11:35:59: 43–
[DEBUG] 11:35:59: Neighbours of device 776) Steckedose1 : [1,114,305,323,325,328,331,372,381,513,425,464,614,619,739,774,778]
[DEBUG] 11:35:59: Last working route used by device 776 : [1]
[DEBUG] 11:35:59: 45–
[DEBUG] 11:36:00: Neighbours of device 778) GarderobeLicht : [323,372,381,430,473,614,619,717,739,776]
[DEBUG] 11:36:00: Last working route used by device 778 : [1,464,473]
[DEBUG] 11:36:00: 46–
[DEBUG] 11:36:00:
Die parentID ist 774 es sollte bzw. ist Gerät Nr. 44. Es wir auch mitgezählt nur es findet keine Ausgabe statt. Das ist die dazu passende api abfrage:
{„id“:774,„name“:„GangSchloss“,„roomID“:0,„type“:„com.fibaro.zwaveDevice“,„baseType“:„com.fibaro.device“,„enabled“:true,„visible“:false,„isPlugin“:false,„parentId“:1,„remoteGatewayId“:0,„interfaces“:[„battery“,„zwave“,„zwaveAssociation“,„zwaveConfiguration“,„zwaveSecurity“,„zwaveSlaveRouting“],„properties“:{„associations“:„[{"endPointId":0,"groups":[{"groupInfo":{"commands":[{"command":"Battery Report","commandClass":"Command Class Battery"},{"command":"Door Lock Operation Report","commandClass":"Command Class Door Lock"},{"command":"Device Reset Locally Notification","commandClass":"Command Class Device Reset Locally"},{"command":"Notification Report","commandClass":"Command Class Notification"}],"name":"Lifeline","profile":"General: Lifeline"},"id":1,"singleChannel":{"max":1,"set":[1],"view":[1]}}]}]“,„batteryLevel“:„92“,„batteryLowNotification“:„true“,„categories“:„["other"]“,„configured“:true,„dead“:„false“,„deadReason“:„“,„defInterval“:„0“,„deviceControlType“:„0“,„deviceIcon“:„28“,„deviceSpecificData“:„xxxxxxxxxx“,„deviceSpecificIdType“:„Serial Number“,„deviceState“:„Configured“,„emailNotificationID“:„0“,„emailNotificationType“:„0“,„endPointId“:„0“,„lastWorkingRoute“:„[1]“,„lastWorkingRouteRequestStatus“:„ok“,„lastWorkingRouteRequestTimestamp“:„0“,„lastWorkingRouteResponseTimestamp“:„1571165913“,„log“:„“,„logTemp“:„“,„manufacturer“:„“,„markAsDead“:„true“,„maxInterval“:„0“,„minInterval“:„0“,„model“:„“,„neighborList“:„[1,323,328,372,425,473,739]“,„neighborListRequestStatus“:„ok“,„neighborListRequestTimestamp“:„1571166246“,„neighborListResponseTimestamp“:„1571304567“,„nodeId“:„102“,„parameters“:[{„id“:1,„lastReportedValue“:0,„lastSetValue“:0,„size“:1,„value“:0},{„id“:2,„lastReportedValue“:5,„lastSetValue“:5,„size“:4,„value“:5},{„id“:3,„lastReportedValue“:0,„lastSetValue“:0,„size“:1,„value“:0},{„id“:4,„lastReportedValue“:0,„lastSetValue“:0,„size“:4,„value“:0},{„id“:5,„lastReportedValue“:0,„lastSetValue“:0,„size“:1,„value“:0},{„id“:6,„lastReportedValue“:0,„lastSetValue“:0,„size“:4,„value“:0}],„parametersTemplate“:„853“,„pollingTimeSec“:0,„productInfo“:„1,14,0,9,0,1,1,2“,„pushNotificationID“:„0“,„pushNotificationType“:„0“,„remoteGatewayId“:„0“,„saveLogs“:„true“,„securitySchemes“:„“,„serialNumber“:„xxxxxxxxxxx,„smsNotificationID“:„0“,„smsNotificationType“:„0“,„stepInterval“:„0“,„useTemplate“:„true“,„userDescription“:“„,„zwaveCompany“:„Poly-control“,„zwaveInfo“:„3,4,61“,„zwaveSoftwareVersion“:“{}",„zwaveVersion“:„1.2“},„actions“:{„getLastWorkingRoute“:0,„getNeighborList“:0,„getParameter“:1,„reconfigure“:0,„requestNodeNeighborUpdate“:0,„setInterval“:1,„setParameter“:2},„created“:1571152070,„modified“:1571152070,„sortOrder“:271}
