Fibaro HC2 Update 4.122. BETA
Nur Beta, kein Stable!
Version 4.122 Beta
This update features migration process from version 3.600, reconfiguring every device, adjusting them for changes which took place in the system. This will assure a possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please, refer to the message that appears in the interface and Notification Center for further instructions after finishing upgrade.
Important!
Updating from version 3.600 may take up to 30 minutes. Do not restart controller during update process.
New improvements:
  • Refurbished layout of Heating Panel - UI improvements in heating zones list, possibility to copy the daily schedule, possibility to set schedule intervals for all week.
  • Extended door lock support - added support for the PIN codes in Block Scenes and Magic Scenes.
    Resolved issues:
  • Error in using the AEON Labs LED Bulb.
  • Stella Z - template does not show the temperature end point.
  • Minor graphic fixes.
Seit zwei Stunden steht nun downloading patch … wird da noch was oder muss ich der Kisten den Strom nehmen und hoffen dass noch alles das ist?
MIB
Strom aus - Strom an. Immer noch 4.211 Beta. aber die Kiste läuft wieder.
Kein Update mehr ab jetzt.
MIB
Mit Betas bin ich da auch vorsichtig…
4.211 Beta
Respekt, aktueller als Fibaro’s Betas. :smiley:
